Air compressors (refers: Aldi)
Discussion in 'UK Motorcycles' started by Rudy Lacchin, Mar 1, 2009.
  1. Rudy Lacchin
    T i m Guest
    Erm, I thought that's what I did? My Dad was (is?) a ships Captain
    (Shell oil tankers) I got taught the right way to coil stuff from a
    *very early* age. This now goes to the point when I see folk winding
    stuff up round there hand and elbow (as my Dad would say "Like an old
    woman winding up her washing line") and have to say "Gis it here" and
    do the job 'properly' myself. ;-)
    Ok. I like the idea of them anyway so might keep my eye out for a
    bargain.
    Cheers, T i m
    T i m, Mar 4, 2009
    #81
  2. Rudy Lacchin
    T i m Guest
    I have loads. And so it seems do those who call me to sort it out!
    You need a manifold of some sort I guess (which I think is what the
    larger 'main' sorta becomes)? I first experimented with them when I
    was 10 by soldering several tubes into the side of an old tin can to
    act as a manifold for my various fish tank air devices. I seem to
    remember it worked very well (even seeing the tin expand slightly
    under the low pressure of my twin piston rotary induction pump).[1]
    Yeahbut, can you give me some examples of HV kit please? Am I likely
    to be using any ... like the Aldi spot blaster etc?
    I think I should have said "they in turn had settled on them as being
    the most reliable / hard wearing out of the others they have tried -
    that could be bought easily ..."? The problem (or it could be seen as
    a good thing) going with something different to everyone else is the
    inter compatibility and availability of the stuff and it's add-ons.
    ie, I could walk into several motor factors / plant suppliers (In MM)
    and get any format of PCL fitting, inc swivels and Y pieces etc, not
    sure you could do the same with VAL or many other, often better, makes
    / models?
    They do sound like good gear that's for sure.
    I have no issue with changing if a) my local place has them in stock
    today (when I go for more PCL's for this new gear), b) they were not
    disproportionately more expensive than PCL's and c) I could convince
    all my mates to change to VAL. ;-)
    Hmm, nearly all the items I've bought recently came with the same
    short fitting (but generally not fitted), and certainly all the Aldi
    ones did (Spot blaster (fitted), rattle gun, ratchet and die grinder).
    On the one I just measured the actual connector part of the fitting
    fitting is about 20mm long with about a 7mm i/d and certainly won't
    fit into a PCL female.
    Cheers, T i m
    [1] That was a lovely bit of kit. Like sitting next to an old steam
    engine on tickover ;-)
    T i m, Mar 4, 2009
    #82
  3. Rudy Lacchin
    T i m Guest
    Trumped, Sim Air TC2000 (twin cylinder, bought from Glyn of this very
    parish).
    I'd have to say the Bambi / Wolf combo is as quiet as the SimAir (and
    has a 25l reservoir). It doesn't even have a dump valve as most
    compressors of that type do, so no 'tssshhhhh' as it cut's off.
    T i m
    T i m, Mar 4, 2009
    #83
  4. I have a cracking little V-twin hand portable direct drive mains jobbie
    that just chuffs along. I'm not 100% sure if it's actually an air comp
    or a fluid pump but it does tyres excellently, although its max pressure
    is around 60psi. Lifting the heads, I discovered rubber diaphragms
    inside and simple one-way valves.
    I picked it up at a boot sale for a tenner years ago and it's been
    superb value for money.
    Grimly Curmudgeon, Mar 4, 2009
    #84
  5. Rudy Lacchin
    T i m Guest
    I borrowed a mates 12V pump the other day to do Dads car tyres and
    that went to something stupid like 150 PSI! It took enough time to go
    from 26 to 32 PSI and was starting to smell a bit hot so I'm not sure
    it would have got to 150 PSI anyway?
    AND it was nearly as noisy as my workshop compressor!
    T i m
    T i m, Mar 4, 2009
    #85
  6. That sounds like the ones I mentioned earlier - sorta stubby wider PCL
    in appearance.
    #86
  7. Rudy Lacchin
    T i m Guest
    Yes, the ones you turn into tyre inflators. ;-)
    http://preview.tinyurl.com/dxz48n
    It would be 'better' if you saw the female part around but I don't
    seem to.
    These (PCL) are everywhere though ..
    http://www.machinemart.co.uk/images/library/product/large/00/000229315.jpg
    Cheers, T i m
    p.s. I've just dug out a 9l piston compressor to give to the mate who
    gave our daughter the MZ. I've found a length of airline with PCL ends
    now just looking for a tyre inflator for him. I'll be sad to lose it
    as I remember they were quite expensive when I got that one (maybe 15
    years ago). And it's not too noisy.
    T i m, Mar 4, 2009
    #87
  8. Rudy Lacchin
    Beav Guest
    I had a Hydrovane for donkeys years and it just "whirred", but a pal needed
    a portable to use for blowing out the inside of computers in schools. It
    needed to be quiet, so I let him have it with the condition that he kept it
    upright at all times as having it lying down would **** it up and it was too
    good to be fucked up.
    I saw it about a fortnight later laying down in the back of his car. It's
    now in need of resurrecting, coz it's not blowing anymore but he can ****
    off if he thinks I'll do it. Some people you can't help, no matter what.
    This was a fucking expensive compressor when I got it too. My studio
    compressor was designed to be used in (mmmm) a studio:) so it makes no
    noise at all and I've left it running for hours before I've noticed it do a
    little "head nod".
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #88
  9. Rudy Lacchin
    Beav Guest
    If that's one of those things that come built into Boosters, the only thing
    they're good for is blowing a tyre up in an emergency and starting an
    argument.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #89
  10. Rudy Lacchin
    Beav Guest
    I know, I could've had it off him last year, but I didn't need it. Didn't
    you get some airbrushes too?
    None of that with mine either. My 3hp home compressor "tshh's though, but I
    don't hear it.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #90
  11. Rudy Lacchin
    T i m Guest
    Hehe.
    It was *like* one of those but in it's own pouch etc. To be fair it
    did the job but I would have been happier (and it would have been
    quicker and quieter) with an old fashioned foot pump.
    And yep, I had one of those as built into the back of yer boost
    starters but I stuck it on the back of my mates starter and nicked his
    blank back panel for mine!.
    T i m
    T i m, Mar 4, 2009
    #91
  12. Rudy Lacchin
    T i m Guest
    Indeed ..
    Nope. I made the mistake of lending my band saw to a neighbour to cut
    out some hardboard figures for a school fete (good cause n that). It
    came back a few days later but with a broken blade. He offered to pay
    for it but I suggested he might like to go and get it as well?
    Another mate borrowed my pressure washer. It didn't come back for a
    while and when I asked after it he admitted it was broken (and it was
    an early Kew jobby with a stainless steel pump). The fact that it was
    broken was one thing but then I found out it had got broken because he
    was 'larking about' spraying his kids and one tripped over the cable
    and ripped the case open ...
    If I ever borrow something I try to treat it better than I would treat
    it if it was my own (and I generally try to look after my own stuff as
    well). I now try to work on two premise:
    Never a lender or borrower be. Dad used to say about lending stuff
    that "you have everything to lose and nothing to gain". Tis difficult
    though and I will sway from that if:
    1) I know they will do their utmost to look after it and
    2) If it does get broken, repair as was as new or replaced if not.
    And that brings me to another awkward thing re lending (or borrowing)
    stuff. If it should just *happen* to go wrong then it can leave you in
    an awkward situation. You feel crap because you never know if it was
    something broken by negligence or it was going to happen anyway.
    If you have borrowed and it just broke 'in-use' you never know if the
    owner believes that it just happened. ;-(
    How you feel about all the above is probably a function of how much
    hip money you have and how hard you have had to work to get the things
    in the first place.
    The ones I don't help are those who repeatedly go round the
    neighbourhood trying to borrow jump leads or a battery charger because
    they can't be asked to get said themselves or just buy a new battery?
    Cheers, T i m
    T i m, Mar 4, 2009
    #92
  13. Rudy Lacchin
    T i m Guest
    I did, I got a whole load of stuff and we (Daughter) did try some of
    it when it first arrived but didn't have time to get into it all then
    and haven't since (which is a shame). I think we really needed some
    practical guidance from someone who knows what hey are doing ...
    either "who sold you that then" (unlikely) or "you don't do it like
    that, you do it like this". ;-)
    Are you 'hard of hearing', it's too far away or do you mean you just
    don't hear it (like folk who like next to a railway track).
    I think you would hear it on the Bambi pump as it's otherwise nearly
    silent.
    Did I hear that lorry air brakes have to be silenced these days?
    Cheers, T i m
    T i m, Mar 4, 2009
    #93
  14. Rudy Lacchin
    I know which ones she suggested so it's not going to be difficult to
    fund out.
    Andy Bonwick, Mar 4, 2009
    #94
  15. Rudy Lacchin
    I've got access to cranes but the difficult part is persuading the
    riggers and crane drivers to get involved.
    #95
  16. Rudy Lacchin
    Beav Guest
    Well you d do it properly then.
    I was looking through Machine Mart's catalogue today and their prices range
    from 35ish quid to 70 odd for recoil air lines.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #96
  17. Rudy Lacchin
    Beav Guest
    I've got a shit load of guitars and piano's though:)
    That's what I need, a manifold.
    VAL are compatible with all HVLP fittings.
    If you know where to go you can. You can even order them online, but no,
    they're not as readily available as PCL fittings.
    And they're fucking plastic. They withstand constant heating and cooling in
    the booth (up tp 80 centigrade and down below freezinf) too.
    Actually, some of the Aldi stuff comes with HVLP fitting too. We ne4eded to
    do some rivetting today and a local firm had borrowed our air riveter so
    *we* had to borrow one, but our next door neighbour firm had a new (in box)
    "Rolston" one sitting there which he let us have for 20 fucking quid (it'd
    have been silly not to buy it at that price coz they're 58 quid at Machine
    Mart). That one came with an HVLP connector. Fucker blathered us with oil
    coz we stupidly overfilled the hydraulic chamber though, which wasn't nice.
    Inside dia of a PCL is 3/16", inside dia of HVLP is 1/4". Doesn't sound like
    much, but it is.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #97
  18. Rudy Lacchin
    Beav Guest
    Yep, it's a standard HVLP fitting is that.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #98
  19. Rudy Lacchin
    Beav Guest
    You've no idea how much of a plonker he can be.
    Wtf's he doing bringing it back *without* a blade?
    Day ain't got no respek.
    My pal who I gave the compressor to leant me a guitar DSP and he said "It'll
    probably come back in better condition than it is now". I suggested that he
    adopt that attitude too, given the number of things he's totalled by
    neglect. I *daren't* list the things he's fucked up though because I'll just
    be called a lying fucker he's *that* bad and the list is that long.
    "If you break it, you've bought it" is my usual parting shot whnen I lend
    stuff out.
    Indeed. It's a problem sometimes.
    It goes deeper than that. Money doesn't buy people's respect for your
    equipment.
    *ding*. A neighbour of mine asked me just before Christmas if I could get
    her a Snap-On 3/8 drive socket set for her husband. I'd let him use mine
    when he needed it, but I *knew* he wouldn't be happy borrowing it again and
    would eventually get one of his own. (or have one bought for him:). Other
    neighbours? Well I wouldn't lend them the crap from under my fingernails.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #99
  20. Rudy Lacchin
    Beav Guest
    Too far away. Tucked in a corner when it's not being used and rolled out the
    back of the garage when it is.
    Come to think of it, it's been a while since I heard the air brakes noise,
    so maybe. Probably actually, given thatit's *bound* to annoy someone,
    somewhere, someday.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
