Air compressors (refers: Aldi)
Discussion in 'UK Motorcycles' started by Rudy Lacchin, Mar 1, 2009.
  1. Rudy Lacchin
    zymurgy Guest
    I think I paid about £18 a length or so. It was compressed air rated
    and galvanised.
    Remember to leave a small tail hanging down at the lowest point with a
    screw-in plug to let any condensation gather.
    I crack it off every few months, so to speak.
    P.
    zymurgy, Mar 3, 2009
    #61
  2. Rudy Lacchin
    I'd just use the standard 20bar 3/4" bore rubber hose that I've got a
    large amount of already.
    The good thing about rubber hose is that you can route it wherever you
    want simply by putting up a cup hook and hanging it off a cable tie
    and if it does develop a hole you either tape over it with gaffer
    tape, put a fixed joint in it or throw it in the stores at work and
    take a new length.
    We throw our airlines off the top of buildings and people drive
    forklift trucks over them on a regular basis so I suspect they'll
    outlast any steel equivalent.
    Andy Bonwick, Mar 3, 2009
    #62
  3. Good plan; I'd leave a lever valve open during downtime. My use of it
    would be irregular anyway, so the system would get ample time to drain.
    Grimly Curmudgeon, Mar 3, 2009
    #63
  4. Rudy Lacchin
    T i m Guest
    And what have they done to you?
    I just need a air point by the bench and another (20' away) by the
    door for taking air lines outside for bike tyres / tools in the back
    yard or our cars in the road.
    I also considered running a plastic (or rubber?) line through the duct
    between the house and garage and having an air point in the lean-to.
    You never know when it might come in handy. ;-)
    Cheers, T i m
    T i m, Mar 3, 2009
    #64
  5. Rudy Lacchin
    When you've got to carry four (or more) 50' lengths of airline down a
    couple of hundred feet of stairs you soon start chucking them off the
    top of the building. I can carry two at a time but they feel heavy
    very quickly so as long as we're cunning about where and when we throw
    them off they never get carried.
    People drive over them because they can't be arsed to go the long way
    round and take short cuts through where we're working. We try to keep
    airlines off the floor but it's not always possible and the only
    indication that someone has driven over them is a momentary lapse in
    power. You'll always get a **** who parks his truck on the lines then
    fucks off but we normally remove the gas bottle and hide it somewhere
    or put a chain between the brake pedal and the steering wheel so they
    can't drive away when they want to.
    #65
  6. Or jack it up and let it back down on blocks that only just keep the
    wheels off the ground...
    #66
  7. Rudy Lacchin
    T i m Guest
    Understood. I have a couple of rubber airlines and they are quite
    heavy (considering). I fancy one of those self-recoiling jobbies but
    they always seem a bit expensive (compared with just coiling the line
    up manually anyway).
    <pictures Tom and Jerry moment looking into the business end of yer
    pneumatic nail gun>
    Sounds like fun at your place. ;-)
    Daughter is really getting into her Tree Surgery apprenticeship and
    playing with all sorts of fun kit. 50' in the air on a MEWP one min
    and remotely controlling a cat tracked stump grinder the next. How
    nice to use kit called "The Predator R28T" or "TimberWolf 190TDHB
    (Turbo)".
    Maybe that's partly why she likes her "MZ ETZ 251 Saxon Tour" (or
    maybe not) ...
    T i m
    T i m, Mar 3, 2009
    #67
  8. Rudy Lacchin
    Eddie Guest
    Do you *really* think you need to put ideas into his head?
    Eddie, Mar 4, 2009
    #68
  9. Rudy Lacchin
    Beav Guest
    They're brilliant for working under shitty cars when there's no room to
    swing a normal ratchet. Mine gets regular use on a lot of other jobs too
    where laziness plays a part.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #69
  10. Rudy Lacchin
    Beav Guest
    We buy a lot of Blue-Point stuff too and it's as durable as Snap-On and
    carries the same lifetime guarantee, but some tools aren't duplicated in the
    two ranges.
    I've no Wifi stuff at all.
    Indeed. Although "Oh" wasn't the word I used.
    It's one of the big issues with tools and compressors. We have a compressor
    that can supply lots of air (it's a 25hp motor doing the work) at 150psi
    with no trouble, but try running two air tools and the spraygun at the same
    time and the bottleneck is the "mains" airline. Instant drop in pressure at
    the spray gun and a slowing down of the other tools. We really need to
    install a wide bore pipe from the compressor to the booth and to install a
    couple of air stations to really benefit from the capacity of the
    compressor, but we've no round tuits laying around.
    Filters aren't usually an issue and we use "VAL" HVLP fittings. PCL's are
    (IIRC) only about 4mm diameter and that's too small for anything HV.
    They've not had VAL fittings then. They defy any attempt to kill them. Being
    dropped, run over by cars, having all sorts of shite dropped on them and
    they still don't break. PCL's were the standard for years though (still is
    for most air tools and pre-assembles airlines) and it's not easy getting
    some folk to change.
    Bog standard PCL if there's a fitting included. Usually they don't come with
    the tools leaving you to buy them yourself.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #70
  11. Rudy Lacchin
    Beav Guest
    Scaffolding pipe's the thing, Cheap, easy to get and easy to cut threads
    onto.
    It'd be fun to see though.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #71
  12. Rudy Lacchin
    Beav Guest
    My compressor is drained every morning. There's nothing like routine and if
    (when) a drain time is missed, it can seriously **** up a paint job. Water
    and Iso & acrylic paints don't mix too well.
    If we miss one morning, it's no big deal, but if we only drained it weekly
    or monthly and forgot, I'd be gutted when I found out.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #72
  13. Rudy Lacchin
    Beav Guest
    You need a larger bore than the standard plastic pipes though.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #73
  14. Rudy Lacchin
    Beav Guest
    A good air line will outlast most people :) The one in our booth is one I
    got off a guy 20 years ago and he used it for **** knows how long before he
    retired. It's been in constant use all its life too and it's still going
    strong with only its original coupler being swapped for a "VAL" coupler.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #74
  15. Rudy Lacchin
    Beav Guest
    But manually coiling them makes them take on a "coil" mentality and they
    won't lie flat and reach where they need to reach. They need to be wound and
    "unwound" as you coil them, but it's far easier to and tidier to have a wall
    mounted springy reel and they're actually not much more costly than a normal
    air line.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #75
  16. Rudy Lacchin
    Beav Guest
    I've got a single. Bought for airbrush work and small "blow-in's". Silent in
    operation but useless for anything but an airbrush. SimAir Studio it is.
    Indeed.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #76
  17. Rudy Lacchin
    Beav Guest
    I've used mine in the *same* room as her watching TV.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2009
    #77
  18. Rudy Lacchin
    He's trying to help.
    I like to believe that there are hundreds of malicious tricks still
    waiting for me to find them but as time goes on it's starting to
    appear that maybe there aren't that many.
    Andy Bonwick, Mar 4, 2009
    #78
  19. Rudy Lacchin
    Eddie Guest
    I'm sure he thinks that too.
    "You can't teach an old dog new tricks."
    Ummm... Adie hasn't told you which hotel we're staying at, has she?
    Eddie, Mar 4, 2009
    #79
  20. Rudy Lacchin
    There's a lot of stuff you can do if you've access to a crane.
    platypus, Mar 4, 2009
    #80
