Aftermarket Air Intake
Discussion in 'Texas Bikers' started by KB, Jun 20, 2005.
  1. KB
    KB Guest
    I've been thinking about getting an aftermarket air intake like a
    Hypercharger or similar. Do these things really increase power or are they
    just snake oil?? Also, how hard is it to rejet the carbs? I'm pretty handy
    with a wrench. The subject here is a 2004 V-Star 650 Custom.
    Cheers,
    KB
    KB, Jun 20, 2005
  2. A less-restrictive intake will help power, but unless the stock intake
    is REALLY restrictive, the new intake won't do much without
    freer-flowing exhaust and re-jetting the carburetors. The new intake
    allows more air in, the new exhaust lets the extra air out without
    excessive backpressure, and the larger jets ensure that the
    carburetors can meter in enough fuel to mix with the extra air. Since
    most bikes are jetted somewhat lean from the factory for to pass
    emissions regulations, the carb re-jet might well have the biggest
    effect of the three upgrades.
    In addition, although the engine in the V-Star 650 is based on the
    old Virago 535, it actually has *smaller* carburetors (28mm vs 34mm)
    to increase low-end response at the expense of top-end power.
    I thnk your bike has Mikuni carbs, so if you have any experience with
    jetting, the carbs on your bike shouldn't hold any surprises.
    Scott Gardner, Jun 20, 2005
