Aerodynamics Question.
Discussion in 'UK Motorcycles' started by Krusty, May 16, 2011.
  1. Krusty
    Probably a dumb question, but if you're driving along, slipstreaming
    behind a van[1], does your presence have any effect on the van, e.g.
    increased drag?
    [1] Several feet away rather than inches.
  2. Krusty
    M J Carley Guest
    Reduced, if any.
    M J Carley, May 16, 2011
  3. Krusty
    Mark Olson Guest
    No idea about a bike but for cars it can actually decrease the drag on
    the leading vehicle.
    Mark Olson, May 16, 2011
  4. Krusty
    Does that mean that "tailgating"[1] is more fuel-efficient for both
    vehicles?
    [1] In quotes as what I mean is following at a certain distance, where
    certain distance is less than the 2 second rule, for example.
    CT, May 16, 2011
  5. Krusty
    Now that does surprise me. So it's win, win then.
  6. Krusty
    In theory, yes. Close enough and the two bodies act as one much longer
    one, which will generate less drag. One reason why speed record
    vehicles are usually very long.
    Ace, May 16, 2011
  7. Krusty
    M J Carley Guest
    If you're close enough, yes.
  8. Krusty
    A slight acceleration boost for the van when you ram into the back of
    it.
    ogden, May 16, 2011
  9. Krusty
    Where's WUN when you need him?
    CT, May 16, 2011
  10. Krusty
    Eiron Guest
    What about a staggered formation - it works for geese?
    Eiron, May 16, 2011
  11. Krusty
    TOG@Toil Guest
    Ain't that interesting. So, and I'm just ruminating aloud here, a ukrm
    French Run is likely to be 'faster' if we all stick together....
    TOG@Toil, May 16, 2011
  12. Krusty
    Dentist Guest
    Depends on the shapes of the van and car. No significant effect unless
    you're within the first vortex off the back of the van (about 2ft), then
    you both get a decrease in drag. You'd have to do this for at least 2
    percent of your total driving time to see a statistically significant
    change in fuel consumption.
    Crash repairs and fines would cancel that out though....
    Dentist, May 16, 2011
  13. Krusty
    M J Carley Guest
    Different physics.
  14. Krusty
    Certainly the case in my experience.
    ogden, May 16, 2011
  15. For anyone who cares to try it...
    I had to do a long m'way trip in shitty cold weather, with inadequate
    winter gear and no fairing. After being pulled by a copper for being too
    close to the truck in front (tailgating for some weather protection), I
    discovered there was a secondary low pressure area about fifty or sixty
    feet behind most full-sized wagons that were travelling at or around
    their max speed of the day (early 80s). Result: I was able to tailgate
    and remain legal.
    Grimly Curmudgeon, May 16, 2011
  16. Goosix.
  17. Krusty
    Yes, really! I know that controlling the airflow off the rear of a
    vehicle is very important, & assumed that another vehicle following
    close behind would upset that flow, making it less effient. Which I
    realise probably isn't an issue with a van, but I'm still surprised it
    makes it /more/ efficient.
    I'm a bit fick, me.
  18. Yes, sort of. Bernoulli found all this shit out hundreds of years ago
    which is about when a fashion for longer thinner ships came about.
    The aerodynamic efficiency of a body is increased in proportion to its
    length. So, if you are close enough that you can be considered the same
    body as the vehicle in front from the perspective of the medium through
    which it is traveling you will both be a little more efficient.
    steve auvache, May 16, 2011
  19. Krusty
    Beav Guest
    It's also why fast jets are generally "waisted" along the fuselage. Starting
    "fat" at the front and getting slimmer before putting the weight back on at
    the arse end.
    Probably :)
    Beav, May 16, 2011
  20. Krusty
    M J Carley Guest
    Kinda: it keeps the cross-sectional area more or less the same as a
    Sears Haack body over the length of the aircraft (Whitcomb area rule).
