Advice on muffler for Yamaha TRX850
Discussion in 'Australian Motorcycles' started by Alix, Jul 12, 2008.
  1. Alix
    Alix Guest
    Just purchased a '96 Yamaha TRX850. It's a very nice bike but the stock
    mufflers make it sound pretty lame.
    What's a good brand of muffler that will bring out the rumble? (Yes I
    know it's Japanese but some of us have kids and a morgage so the best we
    can do is pretend it's an Italian twin).
    Alix, Jul 12, 2008
  2. You mean apart from, say, Akrapovic, D&D or Staintune:
    http://www.staintune.com.au/exhausts/yamaha/Yamaha TRX 850.htm
    Andrew McKenna, Jul 12, 2008
  3. Alix
    Nev.. Guest
    I still can't believe there's still a TRX850 out there with the stock
    mufflers.
    Nev..
    '07 XB12X
    Nev.., Jul 12, 2008
  4. Alix
    justAL Guest
    A full Over race system. You'd be doing a dis-service with any other brand.
    justAL
    justAL, Jul 12, 2008
  5. Alix
    Alix Guest
    It's a second hand import - '96 model 17,000km on the clock but looks
    very different to the Australian model - brembo brakes, bigger carbs and
    Marchesini wheels. Euro style white faced instruments (still with Yamaha
    logos on them), red bike with white frame but different decals. It seems
    the Japs went a little further to replicate the Italian look in their
    local release of the bike but restrictions still prevented the sports
    exhaust.
    Alix, Jul 12, 2008
  6. Alix
    This looks different (bottom of the page).
    http://www.pipemasters.net/sports-motorcycle-exhausts.html
    Knobdoodle, Jul 12, 2008
  7. Alix
    JL Guest
    The jap model didn't ship with Brembos or marchesinis I'm pretty sure
    - you've got something someone has done a nice job of upgrading on -
    the brakes where the only thing dodgy about the trx - I replaced mine
    with R1 blue spot calipers which were a bolt up swap.
    Strongly recommend staintune - it has the nicest note of any of the
    trx's I've heard (and I've heard quite a few) the remus is too raspy,
    the over system is made of unobtainium and is hence deadly expensive.
    Staintune sounds exactly the way it should sound :)
    JL
    (ex trx owner)
    JL, Jul 13, 2008
  8. Alix
    JL Guest
    PS the Japanese model is speed restricted (190 I think), its a cut out
    based on the speedo IIRC (google it) you can change the speedo to Oz
    model to remove the restriction
    JL
    JL, Jul 13, 2008
  9. Alix
    When you get your new mufflers, can I have the old ones? :-D
    BT Humble, Jul 14, 2008
  10. Alix
    corks Guest
    interesting i knew the jap imports came with brembo brakes, didnt know about
    the marchesini's tho (might be the brembo cast ones)
    i didnt mind the sumitomo's on mine, i just went for braided lines and a HH
    goodridge pads.
    the front forks can be a little light weight, stiffer fork springs help out
    there
    i had laser pipes on my first one and roo racing ones on my second
    corks, Jul 15, 2008
  11. Alix
    Des Guest
    I had Magnum carbon fibre on mine, the note was
    fantastic. Magnum pipes are made in Qld, worth
    giving them a call for info on the pipes.
    I found them to be extremely helpful, I had to
    replace a couple of parts on mine, it had been
    down the road before I got the bike.
    Also , I am not sure about the situation is now
    with regards compliance plates, but at the time
    the magnums had compliance plates, but then the
    staintunes didn't.
    I also liked the fact that the magnums could be
    repaired.
    I personally would buy magnums as a first choice
    after having a set.
    I absolutely loved them
    Des
    Des, Jul 15, 2008
  12. Alix
    Alix Guest
    Thanks Des, I'll take your advice. I suppose the final decision will
    come down to the best I can afford. I priced the staintunes at around
    $1300 which is a bit XE.
    And thanks everyone who replied, this is truly a wonderfully supportive
    newsgroup.
    Alix, Jul 15, 2008
