Advantages of small companies: No 327
Discussion in 'UK Motorcycles' started by neal, Oct 19, 2005.
  1. neal
    neal Guest
    NNTP traffic isn't blocked on the company firewall
    neal, Oct 19, 2005
  2. Pint of Tea
    Boots Blakeley, Oct 19, 2005
  3. neal
    A very large Talisker, ta.
    Pip, Oct 19, 2005
  4. neal
    Cane Guest
    Peppermint tea please.
    So who did the "Emperors New Clothes" interview technique work on this
    time?
    Cane, Oct 19, 2005
  5. neal
    neal Guest
    <suspicious> Did you see my CV?
    neal, Oct 19, 2005
  6. neal
    Cane Guest
    It's invisible. Isn't that the whole point?
    Cane, Oct 19, 2005
  7. neal
    MikeH Guest
    Too late. I've still got pictures of naked interviewing in my head.
    MikeH, Oct 19, 2005
  8. Get back to work, you skiving fecker. :O
    Grimly Curmudgeon, Oct 19, 2005
  9. neal
    gomez Guest
    So there is an opening going for a competent network admin jobsworth
    then?
    gomez, Oct 19, 2005
  10. neal
    Could you explain the difference between "competent" and "permits NNTP",
    with reference to Champ's employer's corporate security policy?
    ogden, Oct 19, 2005
  11. neal
    neal Guest
    No, **** off.
    neal, Oct 19, 2005
  12. neal
    neal Guest
    Not only that, but I can connect my corporate laptop to my personal
    pop3 email account, no problem. Fantastic! Tho, for some reason, my
    attempts to send personal email out to a certain SMTP server with
    which you might have a passing acquaintance is met with a " 550 5.7.1
    <>... Relaying denied. IP name lookup failed
    [194.143.169.189]". Any ideas?
    neal, Oct 19, 2005
  13. neal
    Ginge Guest
    Yes, it looks like the SMTP server has been set up properly, so that
    it' won't relay messages from just any tom dick or harry. That IP
    address doesn't even have a matching reverse DNS entry, does it?
    Get your employer to fix their DNS, for starters.
    Ginge, Oct 19, 2005
  14. neal
    From the above, I'd guess that your IP is 194.143.169.189 and you're trying
    to send mail out through a relay that only permits relaying to known domains
    or from known IPs.
    I'd suggest dropping the server admin a mail with that and any other IPs you
    may appear to come from and have him open it up.
    ogden, Oct 19, 2005
  15. neal
    Switters Guest
    Yeah. I know you're a techo-biff so I'll try keep it simple.
    It could be that the SMTP server is trying to obtain a hostname for the IP
    address that you're connecting from. This 194... bit is all it has, and
    it could be making the assumption that as the IP address doesn't resolve
    to a hostname, that you must be some thieving scum bucket spammer, and is
    telling you to **** off.
    Alternatively, if you really are using the sender address of
    <>, it's saying that it doesn't know you, so **** off.
    Entering your real email addy might fix that right up if the server knows
    you and likes you. Of course, you could have altered that for anti-spam
    reasons but it's so not you.
    Switters, Oct 19, 2005
  16. neal
    antonye Guest
    You've not got server authentication on, so it doesn't
    know who you are and thinks you're trying to relay spam.
    Remember that POP3 and SMTP are (usually) different servers
    so unless you've entered a username/password for the SMTP
    then chances are that's the problem.
    Most of the time it works on your home connection because
    it can resolve your connected IP address to that of one of
    it's own customers, so it doesn't need to authenticate you.
    It only becomes a problem when you're away from your home
    network and try to send.
    Anyway, to resolve it in Outlook (most common in this because
    it doesn't set the server auth on by default) you need to
    goto Tools > Accounts and select the account you use to send
    email with, then click the Properties button. This will open
    that email account dialog. On the Servers tab of that dialog
    there is a "My Server Requires Authentication" checkbox which
    you need to tick. If you use a different username/password
    to send email then you can set this under the Settings...
    button, otherwise it will use the same details as your
    POP3 server settings. Click the OKs to close the dialogs and
    try it again. If you're not using Outlook then you'll have
    to hunt for the same setting, but you get the idea.
    antonye, Oct 19, 2005
  17. neal
    PS. The server admin is off for dinner in 5, so it'll have to wait til
    tomorrow.
    ogden, Oct 19, 2005
  18. neal
    gomez Guest
    You missed the "jobsworth", and I missed out the smiley. Here you go
    gomez, Oct 19, 2005
  19. neal
    deadmail Guest
    wrote in message
    Get on with the job you're paid to do and manage your social life at
    home?
    deadmail, Oct 19, 2005
  20. neal
    Which, of course, only works if the server supports authentication.
    Which it doesn't. Probably.
    ogden, Oct 19, 2005
