Adjusting counterbalancer chain tension on KLR650
Discussion in 'Motorbike Technical Discussion' started by krusty kritter, May 18, 2005.
  1. How do you adjust the counterbalancer chain tension on the KLR650?
    I lost my owner's manual but I remember it had something to do with a
    bolt under a rubber plug on the left side of the engine...
  2. Thanks for the info, Sam. I have the second year KLR600, which is
    actually 564cc, not 650cc...
    I just pulled the neglected garage queen out of storage again and am
    planning to ride around on rough narrow paved roads in the local
    foothills and national forest areas. It only has 4K miles on it after
    20 years in my garage. I ride the other three bikes a lot more...
    I have always noticed strange rattles and clanks and buzzes. The engine
    will sometimes suddenly clank and stop from an idle. I hear the clank
    from the left side of the engine, but it may be that the transmission
    is suddenly popping out of neutral into gear. I've had that happen
    while sitting on the bike while it's idling in neutral and the bike
    lurches forward and stalls.
    And that silly KACR automatic compression release will stick and hold
    the exhaust valve open and I can't kick the damned thing over fast
    enough to deactivate the KACR. I have to always have a good battery to
    crank it fast enough to overcome the KACR...
    Then there is the buzzy kick starter lever. Inadvertently push against
    it with my ankle, and I can hear it buzzing as it tries to engage the
    ratchet...
    Yesterday, while battling to kick start the engine, I felt my knee hit
    that red knob on the kill switch, breaking it off. I figured out how to
    bypass the kill switch so I could start the engine. But the petcock
    leaks like a sieve, so I need new rubber parts for it.
    The kill switch/starter switch costs about $40 to $50 for a new one,
    but I figure I don't really need a kill switch anyway. It's always been
    impossible for me to thumb the starter button with my small hand on the
    throttle, I have to push the starter button with my left hand, while
    working the throttle with my right hand. That's why I bypassed the
    clutch safety interlock switch. Otherwise, I need three hands to start
    the Kwacker when it's in gear...
  3. Hey, leave the counterbalancer chain off entirely! ;-)
    You got carpal tunnel or somethin' ?
    Michael Sierchio, May 18, 2005
