adjusting chain
Discussion in 'Motorbike Technical Discussion' started by matt neumiller, Jul 1, 2004.
  1. hello all!
    i got myself a new 2003 triumph sprint st this spring, and i am
    thinking it may be time to adjust the chain. the manual gives good
    instructions on accomplishing this, but i cannot figure out one part.
    it says that i should find the 'tight' spot in the chain and take my
    measurements there. how do i find the tight spot? i know the rear
    cog is slightly eliptical and all, but not enough that i can easily
    see a 'tight' spot when turning the wheel.
    also, is there some kind of gauge or tool to help in measuring chain
    play?
    thanx all,
    matt n
  2. matt neumiller
    Mark Olson Guest
    The variation in chain slack is not due to either sprocket being
    out of round- the links of the chain don't all wear at the same
    rate. When the chain is near the end of life, this uneven wear
    can result in noticeable variation in the amount of slack as you
    turn the wheel. On a newer chain there shouldn't be much wear,
    and even less difference in wear between any two links, so there
    should be little if any change in slack as you turn the wheel.
    A ruler, hold it up next to the chain, resting the end on the
    swingarm or some fixed point, and look at the excursion of the
    chain as you pull it up and down. The total amount of movement
    of the chain (usually 1/2 way between the sprockets) is the
    measurement of interest.
    Mark Olson, Jul 1, 2004
  3. Hi Matt ;->
    As the other folks have said, the chain will be tighter when sitting on
    the bike, but What the manual is referring to, (like Mark said, is that
    the chain wears unevenly, and the sprockets are not perfectly round) is
    the place during the rotation of the wheel where the chain is the
    tightest. If you have a center stand, put it in neutral, and rotate the
    back wheel, you'll notice that at some points in the revolution of the
    chain, it will sag a little, and other points it will be tighter. Using
    a ruler, or better yet, a combination of your finger pressure on the
    lower part of the chain (pushing towards the ground) and a ruler or keen
    eye, rotate until you find the tightest spot. Adjust from that spot, and
    you got it!
    Good Luck with Your Trump!
    Paul
    Sportster4Eva, Jul 1, 2004
  4. matt neumiller
    Pete Guest
    A contibuting factor might be the chordal action, where the chain contacts
    the sprockets, especially the front one. The chain would become slightly
    tighter as it climbs onto the sprocket.
    D.
    Pete, Jul 1, 2004
