AD: Madman Engineering.com
Discussion in 'Motorbike Technical Discussion' started by MADMAN ENGINEERING.COM, Nov 1, 2003.
  1. We offer custom camshafts for all Motorcycle & ATV's also 2&4 stroke
    porting, Wiseco & Pro X pistons, Carrillo rods, stainless steel or titanium
    oversized valves,
    big bore cylinder sleeving, and complete crankshaft rebuilding.
    http://www.madmanengineering.com
    Thanks Martin
  2. Do you want your account pulled, you sad little gob of sputum?
    The Older Gentleman, Nov 1, 2003
  3. MADMAN ENGINEERING.COM
    Charlie Gary Guest
    Hey Martin,
    the group might not complain about your spam if you were to answer some
    camsfhaft questions.
    Charlie Gary, Nov 3, 2003
  4. Sure,
    I have worked with a lot of camshafts, it depends on the application and
    valve configuration as per what camshaft to use, most order cams way to big
    for what there doing, some feel that they need a high lift cam with lots of
    duration, fine for drag racing where the engine will never see below 8000
    RPM's, but most on & off road racers want a cam that will produce more
    torque than horsepower.
    Anybody that has any other questions feel free to call me 618-949-3898
    Thanks Martin
    MADMAN ENGINEERING.COM, Nov 11, 2003
