Ad-blocker
Discussion in 'UK Motorcycles' started by Gingerposer, Sep 29, 2003.
  1. Gingerposer
    Gingerposer Guest
    please recommend me a good free one. go on, go on.
  2. Gingerposer
    Robbo Guest
    Nicked from Canes posting around a month ago
    NoAds
    http://www.southbaypc.com/
    Robbo
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Sep 29, 2003
  3. Gingerposer
    http://www.proxomitron.info/
    It's free and it works.
    I've not seen a pop-up since installing it - and it does a lot of
    other stuff too. Just remember to click on the Proxomitron logo after
    a restart, before you go surfing (otherwise it won't let you access
    the net, see) and away you go.
    Pip, Sep 29, 2003
  4. Gingerposer
    Steve Guest
    If you're on Windows and use IE, then download the Google toolbar, as it
    blocks pop-up ads very well. Mozilla has recently duplicated this
    functionality in its browser.
    Steve, Sep 29, 2003
  5. Gingerposer
    tallbloke Guest
    nice one Pip. I like this one. Before, I just stuck a list of all the
    adservers in the world into the windows hosts file and set their addresses
    to be localhost, which worked, insomuch as inline ad frames on webpages
    just looked like little 404 pages. The disadvantage was that you needed to
    hit the back button several timea to back out of a page with several ad
    frames on. This sorts that problem neatly.
    Ta M8 :)
    tallbloke, Sep 29, 2003
  6. Gingerposer
    tallbloke Guest
    No. Don't. Honestly, it's not a good idea.
  7. Gingerposer
    I thought that the google toolbar was spyware, is that why?
    Muck
    Bandit 600n(With added ducktape); CG125(MSOTHPR)
    "I've got a CG125, and I'm not affraid to use it."
    DS#1 ; DOMO#1 ; SH#2 ; ICQ: 166144431
    Remove _TEETH_ to e-mail
    Muck, Sep 29, 2003
  8. Gingerposer
    What Pip says...
    Good bit of kit it is, does what it says on the tin, and a hell of a lot
    more. Should be a standard bit of kit on every web connected Windows box.
    Muck
    Muck, Sep 29, 2003
  9. tallbloke wrote
    I just been to this site using opera and from what I can see on the test
    page I have already got it turned on enough and don't need no extra pop
    up killer stuff. Which is nice.
    steve auvache, Sep 29, 2003
  10. Gingerposer
    Cane Guest
    Cane, Sep 29, 2003
  11. Gingerposer
    Steve Guest
    [snip]
    It asks you whether you want to send information to Google when you install
    it, it's quite simple to click 'no'.
    Steve, Sep 29, 2003
  12. Gingerposer
    Mash Guest
    Mash, Sep 29, 2003
  13. Gingerposer
    Ben Guest
    It's spyware in the sense that it tells Google what you've been
    searching for and your IP etc, yes. But then they can glean that
    information from you using the webpage.
    Ben, Sep 29, 2003
  14. Gingerposer
    Gingerposer was seen penning the following ode to ... whatever:
    Mozilla Firebird is *very* good at blocking pop-ups and -unders.
    Timo Geusch, Sep 29, 2003
  15. Gingerposer
    Ben Blaney Guest
    Turn the computer off and listen to Radio Four.
    Ben Blaney, Sep 29, 2003
  16. Gingerposer
    tallbloke Guest
    I recommend the use of the google proxy at
    http://www.google-watch.org/cgi-bin/proxy.htm
    for subject matter sensitive searches.
  17. Gingerposer
    tallbloke Guest
    Lol, the naievete of youth.
  18. Gingerposer
    tallbloke Guest
    Just because I make use of the sites proxy onto google it doesn't follow
    that I believe the content of the site does it Champ?
    Not at the school of logic I went to.
    Not sure what you are referring to anyway, it's all pretty factual stuff
    that you can draw your own conclusions from, or not.
    tallbloke, Sep 30, 2003
  19. Gingerposer
    tallbloke Guest
    Ok.
    But remember, just because I'm paranoid, doesn't mean they're not
    watching you ;-)
  20. Gingerposer
    tallbloke Guest
    Champ <> spouted the following in
    from the site:
    Google's toolbar updates to new versions quietly, and without asking. This
    means that if you have the toolbar installed, Google essentially has
    complete access to your hard disk every time you connect to Google (which
    is many times a day). Most software vendors, and even Microsoft, ask if
    you'd like an updated version. But not Google. Any software that updates
    automatically presents a massive security risk.
    Not particularly 'X Files' is it?
Similar Threads
Loading...
