Acidic maths
Discussion in 'UK Motorcycles' started by Mungo \Two Sheds\ Toadfoot, Aug 3, 2009.
  1. I've acquired a quantity of 77% sulphuric acid. Not enough to melt people,
    unfortunately, but loads more than enough to fill the spare battery I have
    sitting here. Now, I find that batteries like ~35% acid so would I be right
    in thinking that a roughly equal mixture of this acid and water would do the
    job or am I talking complete bollocks as usual?
  2. Mungo \Two Sheds\ Toadfoot
    Colin Irvine Guest
    No, you're right. You actually want to add a little over an equal
    amount of water - 110% to be precise.
    Colin Irvine, Aug 3, 2009
  3. Mungo \Two Sheds\ Toadfoot
    Eiron Guest
    Never add water to acid. It's one of the two things that make you go blind,
    at least according to my teachers many years ago.
    Eiron, Aug 3, 2009
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Colin Irvine
    And FFS remember "Always do what you oughta - add the acid to the
    water".
    go and talk to the Catholics.
    Wicked Uncle Nigel, Aug 3, 2009
  5. Mungo \Two Sheds\ Toadfoot
    Colin Irvine Guest
    Bugger - 120% I think.
  6. Mungo \Two Sheds\ Toadfoot
    Colin Irvine Guest
    <g> I used to think of Sulphuric and Water as Sailors and Women.
  7. Mungo \Two Sheds\ Toadfoot
    Adrian Guest
    No, you were right with 110%.
    1 litre of 77% acid contains 770ml neat acid and 330ml water.
    770ml acid to 35% would be 770ml acid and 1430ml water.
    1430ml minus the 330ml you've already got would be 1100ml added or 110%
    of the 1 litre you started with.
    Adrian, Aug 3, 2009
  8. Thanks, and to the others for considering my eyesight. I always think of it
    as A to W.
  9. Mungo \Two Sheds\ Toadfoot
    Colin Irvine Guest
    That's how I got 110%. Then I realised the initial mixture would be
    770 to *230* and 1200 added ...
  10. Mungo \Two Sheds\ Toadfoot
    crn Guest
    Not just any water - distilled water.
    Allways add the acid to the water NOT water to acid.
    For battery use you should measure the specific gravity using a hydrometer,
    the most common values are 1.230 or 1.260 but check the battery specs
    because my memory has been known to suffer random bogosity.
    crn, Aug 3, 2009
  11. Mungo \Two Sheds\ Toadfoot
    Sounds about right. Just be sure to add the acid to the water, not the
    other way around.
    ogden, Aug 3, 2009
  12. Mungo \Two Sheds\ Toadfoot
    TMack Guest
    Just make sure you add acid to water if you are diluting it. 77% is rather
    concentrated and adding water to concentrated Sulphuric can have unfortunate
    consequences in terms of spatter. I doubt if 77% is strong enought to cause
    a major spatter problem but no need to take any chances.
    TMack, Aug 3, 2009
  13. Mungo \Two Sheds\ Toadfoot
    Adrian Guest
    <cough>
    OhYesSoItWould
    Adrian, Aug 3, 2009
  14. Mungo \Two Sheds\ Toadfoot
    Beav Guest
    I always thought it was the other way round and if not, then toping up
    batteries with water must be a pretty dodgy exercise.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 3, 2009
  15. Mungo \Two Sheds\ Toadfoot
    Beav Guest
    Me too, as I posted a minute ago. It's fucking odd how an idea stays planted
    innit?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 3, 2009
  16. Mungo \Two Sheds\ Toadfoot
    Battery acid is already diluted. It's adding water to concentrated
    acid that's supposed to be bad.
    Ace, Aug 3, 2009
  17. It's diluted enough in batteries not to matter.
    But when diluting concentrated sulphuric acid, that's how you do it.
    The acid wants to be hydrated so much it fights itself to grab hold of the
    water, so to speak. That's what causes the spitting.
    That's why concentrated sulphuric acid burns so badly if contacting flesh,
    it acts as a desiccating agent as well as an acid.
    Andrew Halliwell, Aug 3, 2009
  18. Mungo \Two Sheds\ Toadfoot
    Colin Irvine Guest
    Damn right. I can still remember the chemistry lesson where the
    teacher chucked some sugar into concentrated sulphuric acid. The acid
    took all the hydrogen and oxygen out of the sugar (it was in there in
    the same 2:1 ratio as water) leaving a great pillar of carbon emerging
    from the flask. We were impressed.
    Colin Irvine, Aug 4, 2009
  19. Mungo \Two Sheds\ Toadfoot
    muddy cat Guest
    I remember that one too. I also remember being beaten about the head and
    shoulders by my dad after an experiment in the garage with sugar and
    saltpeter had a greater yield that I expected.
    muddy cat, Aug 4, 2009
  20. Mungo \Two Sheds\ Toadfoot
    I have the scars of a large 97% sulphuric acid explosion at Dounreay.
    It's ability to eat through my protective lab coat and clothing was
    impressive and the wounds took over a week to close. TBF the perspex
    helmet and synthetic gloves did mostly survive.
    Hog, Aug 4, 2009
