ABS - worthwhile?
Discussion in 'Australian Motorcycles' started by Andrew Price, Nov 9, 2007.
  1. Andrew Price
    Andrew Price Guest
    Anyone with ABS ever used it?
    Worthwhile?
    Worth $500?
    New chook chaser is offered with it for extra money. Can see the point with
    a car - but not sure if worth it on a bike?
    Opinions appreciated.
  2. Andrew Price
    Boxer Guest
    I had ABS on my K1100LT, it only saved my life once.
    Boxer
    Boxer, Nov 10, 2007
  3. Andrew Price
    Grump Guest
    It's the last thing you'ld want if used on dirt.
    G.
    Grump, Nov 10, 2007
  4. Andrew Price
    Smeegels Guest
    So you died a few times since?
    Smeegels, Nov 10, 2007
  5. Andrew Price
    justAL Guest
    Quite worthwhile and very effective.
    justAL
    justAL, Nov 10, 2007
  6. Andrew Price
    Boxer Guest
    How does ABS cause you to crash?
    If true you could sue BMW for millions.
    Boxer
    Boxer, Nov 10, 2007
  7. Andrew Price
    I didn't actually crash but I had a few hairy moments when it let the brakes
    off for a meter-or-two after hitting a little bump mid downhill-corner.
    Brown undies those days!
    Knobdoodle, Nov 10, 2007
  8. Andrew Price
    Peter Wyzl Guest
    Maybe I misunderstand, but that still sounds better than locking up in that
    circumstance....
    P
    Peter Wyzl, Nov 10, 2007
  9. Andrew Price
    P'raps I'm not describing it well but all that would've happened was the
    back tyre would've chirped a little as it momentarily locked,
    but instead the ABS released BOTH brakes!
    Sure they grabbed again after a rotation (or maybe less; these moment tend
    to elongate when you're panicking) but it was still a period during which I
    had no control.
    I'm sure just one meter doesn't sound all that dramatic to you but I can
    assure you that it absolutely scared the crap outta me!
  10. Andrew Price
    Peter Wyzl Guest
    No, now I'm on your page. Releasing both for a single lock is ...
    problematic ...
    I guess I never really thought about the mechanics of it all, but that does
    sound a little pucker inducing...
    P
  11. Andrew Price
    Boxer Guest
    My 1200 is not power assisted.
    Boxer
    Boxer, Nov 10, 2007
  12. Umm, why? Either you release the brakes or the ABS does. What's the
    difference? End result is the same. Seems a waste of effort to me.
    I installed a switch in my Lancer GSR to turn off the ABS when I
    wanted. I must say it had very good ABS though and it rarely cut in,
    only when the car was really being pushed. Compared to my mate's WRX
    which seemed to cut in waaaaay too early, it was great. But I still
    wanted to be able to practice braking under my own control.
    Cheers
    Kev
    Kevin Gleeson, Nov 10, 2007
  13. Andrew Price
    Dale Porter Guest
    ABS can be fooled by certain situations and road conditions. In Tims case
    (if I recall correctly) it was a matter of a dirt road with little-to-no
    traction. ABS sensed a lockup and backed off the brakes (as it's supposed
    to), but it kept backing off the brakes to the point of Tim having no
    brakes. The ABS system was fooled by the loose gravel road and the constant
    wheel slip.
    Cheers,
    Dale.
    Dale Porter, Nov 11, 2007
  14. Andrew Price
    On a billiard-table smooth straight bitumen road maybe; but throw in ripples
    and potholes and my R1100GS's ABS was meters worse than "normal" braking.
    On gravel it was just stupid! (Although this is probably more due to my
    non-ABS "minimal front, heavy rear" dirt braking than any actual mechanical
    shortcoming)
    Knobdoodle, Nov 11, 2007
  15. Andrew Price
    Peter Wyzl Guest
    Yer on the money there... GPS updates once a second, and is good for
    consistent speeds in straight lines, not rapid changes in speed and or
    direction, certainly not suitable for this type of application.
    P
    Peter Wyzl, Nov 11, 2007
  16. Andrew Price
    Nev.. Guest
    Nev.., Nov 12, 2007
  17. Andrew Price
    Chris Smith Guest
    Well, that's kind of missing the point. ABS is there to pull you up
    quicker (and safer) than you could yourself in those situations where
    your eyeballs are bulging out of the helmet and the seat is
    disappearing up your arse, not when you've got time to pick a nice bit
    of road and a landmark to measure against ;). It's not hard to do a
    good emergency stop when you're ready for it.
    With that said, 40% is a load of crap. I'd be willing to bet that
    comes from comparing the 7-8 year old bikes w/o ABS to the new ones
    with it (and even then - that's a *huge* improvement). But it's
    coppers (and American ones at that) - you can't expect much honesty
    out of them.
    I've not experienced ABS on a bike, but I used to have a car with it -
    and while I could pull the car up quicker in controlled conditions
    with the ABS "off", the few times I ever had it cut in I have little
    doubt it saved me from accidents - albeit relatively minor ones. I'd
    have to rate ABS as an overall plus - if I were buying a bike new I'd
    get it.
    Chris Smith, Nov 12, 2007
  18. Andrew Price
    Boxer Guest
    I recently purchased a new R1200GSA, and having had 2 previous BMW's with
    ABS and many without I voted with my wallet and ticked the ABS box. It only
    has to save your life once to pay for itself, and you are quite correct it
    is a safety net to cover your arse when the shit is really hitting the fan.
    Boxer
    Boxer, Nov 12, 2007
  19. Andrew Price
    Mr_Hankey Guest
    I thought MB was a(n) MB Cop? No?
    Mr_Hankey, Nov 13, 2007
  20. Andrew Price
    Nev.. Guest
    I reckon if you took two Harleys up to speed and stomped as hard as you
    could on the rear brake pedal, the one with ABS would probably stop in
    40% less space than the one without. I'm sure Keith Urban is going to
    option up to ABS on his next bike, so the next time someone does an
    illegal u-turn in front of him, and he has no choice but to drop his
    bike, he can drop it 40% sooner.
    Nev..
    '04 CBR1100XX
    Nev.., Nov 13, 2007
