ABS brakes?
Discussion in 'Motorcycle Technical Discussion' started by Paul Harris, Oct 6, 2005.
  1. Yes yes yes. ABS is great, you can grab your brakes really hard without fear of sliding the tires. That can be a
    lifesaver in an emergency when we don't have time to think or modulate the brakes perfectly. On the track coming up to a
    corner you know well and squeezing the brakes just right is not the same as when you see a deer in front of your bike!
    I only recently got an ABS BWM and I always thought my skills would be enough, but I love this ABS. Of course you need
    to realize it's limitations and remember you CAN grab a great big handful of brake in an emergency. You have to change
    your thinking. If you don't remember to grab lots of brake, it won't help you. Keeping the wheels rolling is a big plus
    in avoiding going down. Especially if you're not perfectly upright. I used to slide the wheels once in awhile with no
    big deal, but only if the bike was fully upright could I keep it upright when a wheel slid.
    Read all about ABS, then get out and test it, think about it, and enjoy it.
    James B. Davis, Nov 7, 2005
  2. Ya sure. You read the darnest thing on the net.
    Let's put it this way: ABS brakes work as normal brakes until one wheel locks up. It's well known that a locked up brake
    doesn't stop as well as one that's still got traction. That's what ABS does, it keeps your wheels in traction.
    Not to mention, it allows riders with less skills than professionals and in less than ideal conditions to brake quickly
    and safely. Your mileage may vary.
  3. On all Beemers you can also turn it off. Nobody does.
  4. Case in point here: I recently picked up a 1988 BMW K100RS with the first year of ABS. The bike had sat for 4 years when
    I got it. The bike needed lots of work. But the ABS works, and I didn't have to do anything to it. High maintenance?
    Yes, maybe, if you break something, but rarely does anything wear out. Other makes may vary...
  5. Mark, get on over the the tech sections of the IBMWR list. Lots of good help to get your ABS working again. First of all
    though, you need a good battery. Low voltage will cause the ABS to not click in. They also have some tests for finding
    out what fault you have and how to reset your ABS computer so it will work again. Good luck, usually something simple
    like the ABS gap is at fault.
  6. Paul Harris
    Don Fearn Guest
    No, actually, that isn't true. My 2001 R1100S with ABS doesn't have a
    way to turn it off, and I believe that only the GS models have that
    option.
    If I could, I wouldn't. Unless maybe when I was riding in gravel, but
    I rarely do, so no, I wouldn't turn off my ABS . . . .
    -Don
    Don Fearn, Nov 7, 2005
  7. Paul Harris
    David Kelly Guest
    There *is* truth to that claim. See below.
    Exactly. Only the very very very best professional racer brakes as well
    the very first time as does consumer grade ABS. After practice every
    professional racer can brake better than consumer grade ABS.
    One could brake better without ABS if one is exceptionally good. But in
    situations where its needed very few are that good.
    David Kelly, Nov 7, 2005
  8. I would like to see any human be able to modulate the brakes 10 times a
    second. It is just not possible. Bosch ABS modulate up to 15 times a second
    and that is standard consumer grade ABS. Add to that the fact that each
    wheel in independently controlled and you have a situation that no pro could
    possibly beat.
    If one were to compare a pro to Ford or GM's first generation ABS, yes I
    would say that the pro driver will beat their ABS.
    pierce
    R. Pierce Butler, Nov 7, 2005
  9. I, and several others of the time, were able to outbrake BMW's
    first-generation ABS system.
    I daresay it's improved since.
    So I'd definitely agree with you here.
    The Older Gentleman, Nov 7, 2005
  10. Paul Harris
    Mark Hickey Guest
    Thanks for the feedback. I've changed my battery, and have followed
    the reset instructions (curiously, that USED to work, now it doesn't).
    I also followed the diagnostic process, but no joy. I think I just
    need a new / repaired computer. Sigh...
    I wish I could find a schematic for the "brains box" - the problem
    would likely be fairly easy to diagnose if I had that (I'm betting the
    same thing goes wrong with virtually all of 'em, since they all seem
    to exhibit the same symptoms after they fail).
    Mark "at least the non-ABS mode works well" Hickey
    Mark Hickey, Nov 7, 2005
  11. Well, I looked at an actual test of ABS on a street bike. They took a
    bike that has both ABS and non-ABS available -- a ST1300 -- and a bike
    where it's switchable -- a BMW GS -- and did a comparison of ABS vs not
    ABS with a race driver, a regular "experienced" motorcyclist, and a
    "new" motorcyclist. On clean, dry pavement, a race driver could beat ABS
    by about 20 feet of stopping distance on a 75mph->0mph stop, while the
    experience motorcyclist managed to equal it (the new rider, on the other
    hand, stopped faster with ABS than without). The equation changed when
    you made the pavement wet. There even the race driver took as much as 60
    ft more to stop than ABS took.
    Conclusion: If all you ever ride on is clean, dry pavement, and you are
    a race driver, ABS is a waste. If, on the other hand, you ride a touring
    bike or use your bike as your sole means of transportation good weather
    or bad, ABS is a godsend, because when you ride in the rain it'll keep
    your bike from flipping ends and will bring you down to a halt far
    faster than non-ABS brakes.
    - Elron
    L. Ron Waddle, Nov 7, 2005
  12. Paul Harris
    Seth Guest
    Really? I can find no mention of that in the manual for my '02 K1200RSA nor
    can I find a switch for it.
    I did have a switch for it on my GS however. Unfortunately if the ignition
    was reset (like if you stall while going down a steep, rocky slope) you had
    to re-disable it.
    Seth, Nov 8, 2005
  13. Paul Harris
    David Kelly Guest
    Other than the fact there were about 7 bleeders it wasn't an issue at
    all on my 2002 GL1800. Nor 1993.5 Infiniti G20. Simply use new brake
    fluid to push the old out. It *could* be quite a mess if one drained the
    system first the way the GL1800 service manual states.
    The GL1800 has 7 brake bleeders whether its ABS or not. Brake pedal
    applies to a couple of pistons up front. Brake lever applies to one of
    the three pistons in rear in addition to 4 pistons up front.
    David Kelly, Nov 8, 2005
  14. Paul Harris
    David Kelly Guest
    The human doesn't have to modulate the brakes, the human applies linear
    pressure while the ABS computer can only pump a momentary disconnect
    followed by a hard stomp.
    I do believe ABS is better in every situation but where the human gets
    to practice before taking the exam. In that situation a good ABS should
    be able to equal the human.
  15. Paul Harris
    OH- Guest
    Wow, a car with a will and some sort of AI. With the
    traditional models it used to be the driver who wrapped
    the car around immovable objects.
    OH-, Nov 8, 2005
  16. (The Older Gentleman) wrote in
    Bosch's first generation ABS was better than GM's or Ford's. The second
    generation (maybe third?) raised the modulation rate to something like 30
    times a second, a rate that is impossible for a human to achieve.
    pierce
    R. Pierce Butler, Nov 11, 2005
  17. GM's or Ford's must have been crap, then. Mind you, I'm talking about
    BMW's first-generation bike ABS system, fitted (IIRC) to a K100RT in the
    mid-to-late 1980s.
    The Older Gentleman, Nov 11, 2005
  18. (The Older Gentleman) wrote in
    God yes. BMW would rather not be reminded about that ABS system. It was a
    pretty good first attempt.
    pierce
  19. Depends on the year of ABS. The new bikes are a nightmare to bleed no doubt. My old 1988 K100RS has a simple system. You
    bleed the two ABS units, then the calipers as normal. No big deal.
    James B. Davis, Nov 12, 2005
  20. Think about a sudden need to brake HARD. There is a time lag for even the expert to get a good handful of brake. With
    ABS you can just brake HARD NOW. Makes a big difference if you only have a second or two to scrub off speed.
    We don't all have the ability to stay calm and think about what we're doing in an emergency. That is why ABS is go
    great, you don't have to, you just brake hard now.
