About to start crying
Discussion in 'Motorcycle Technical Discussion' started by Ninja Stevie, Feb 18, 2006.
  1. Ninja Stevie
    Ninja Stevie Guest
    Well, thought I'd prepare my bike (1999 zx6r) for its MOT. The main
    problem was the brakes, the pads were completely worn, the pistons
    seemingly frozen, and the brake fluid pretty gunky.
    I bought some new pads, some brake dust cleaner and some brake fluid.
    Bearing in mind that Ive never done this sort of thing, I thought Id
    take the calipers off the forks because I reckoned it would be easier
    cleaning them unattached. Got them fairly clean. So far so good.
    I attached them back on and changed the bike fluid, so that I could
    then force the pistons out of the casing and finish off the cleaning.
    Again, seemed to go without a hitch, all the air bubbles were out, both
    sides done.
    I was just finishing this little job by fastening the final bleeding
    screw back, and all of a sudden it seemed very easy to turn. I hadnt
    unscrewed it very far, so i turned it just a little bit more, and a bit
    more, until it went incredibly easy to turn - the case surrounding this
    little screw had just come off completely - snapped! Hardly any
    pressure whatsoever!
    Oh my, I've just had a quick look on the t'internet at prices for this
    front right caliper, and they all seem to be about £500 (UK). I cant
    afford these sort of prices! Please someone tell me theres another way
    of recovering my situation other than forking out for a new pair of
    calipers.
    Yours Desparately
    Steve
  2. Ninja Stevie
    FB Guest
    Don't get depressed. Get busy fixing the problem so you can go on to
    better things.
    Start checking ebay, and call up all the breakers in the country to see
    what you can buy used.
    An alternative would be to take the caliper to a really good
    trustworthy machinist and have him rework the damaged caliper. This
    might involve welding the original hole shut and redrilling and tapping
    the bleeder screw hole, unless you can find oversized bleeder screws.
    When it comes right down to the nitty gritty, you do not need those
    bleeder screws anyway, after you get the caliper full of brake fluid.
    If you unbolt the calipers and let them hang straight down, you can put
    a piece of 1/4 inch steel plate between the pads to keep them from
    blowing out as you pump the lever, all the air bubbles will rise up the
    hoses to the master cylinder reservoir.
    That's how I bleed brakes.
    Or, if you can find a trustworthy welder, just have the damaged bleeder
    hole welded shut and install a bleeder style banjo bolt where the brake
    hose attaches to the caliper.
    Google for "bleeder banjo"...
    I think Galfer or some manufacturer of steel braided aftermarket brake
    hoses makes banjo bleeders for about $15 USD.
    The main idea for the banjo bleeder is to install it up at the master
    cylinder so you can bleed out the air bubble that accumulate in that
    critical area.
    Air bubbles right there cause the front brake lever to feel spongy and
    riders keep trying to bleed the air out down at the caliper and have no
    success getting the air out.
    For some reason, riders don't seem to understand that air bubbles rise
    and brake fluid goes to the lowest point in the system.
    If you find metric banjo bleeders, they will probably come in 10 and 12
    millimeter diameters with two or three different thread pitches. You
    must get the correct thread pitch or you'll just cross thread the
    damned things. Thread pitches are typically
    0.75 mm, 1.0mm, 1.25mm and 1.5mm, with the most common used being 1.0mm
    between threads.
    FB, Feb 18, 2006
  3. Ninja Stevie
    John Johnson Guest
    Have you checked used prices? I've seen complete front brake systems go
    for $1-200 on eBay in the past. People sell them when they crash the
    bike or when they put on aftermarket brakes.
    Even if you get a dirty set, you can strip and clean them, replacing all
    seals, any corroded pistons, etc. This would be a good time to consider
    adding speed-bleeders (http://www.speedbleeder.com/) if that seems
    worthwhile. Some people really like them, I just haven't bothered since
    I've get access to a MightyVac setup (pump the fluid in from the bottom
    of the system, slowly, and bleeding is usually not necessary, IME).
    You'll want the workshop manual for the disassembly, and people here can
    walk you through the process too, most likely. fwiw, BIKE had a sidebar
    or article about doing this procedure on a CBR900RR late last year. I
    could look up the article if you wanted to try and track it down.
    As for the desperation, take three deep breaths, assess the situation,
    and make a plan. If you get frustrated, take some time off. I've found
    that no matter how important or time-sensitive a project is, I'm better
    off taking some time off rather than working while upset. I forget less,
    I break less, I hurt myself less. I guess I'm trying to say that I've
    been there too.
    Finally, this example really makes the case for regular brake caliper
    cleaning and fluid change. I change my fluid every year or two and clean
    and lubricate the calipers at least once per year. I've decided that
    cleaning the pistons and lubricating the slide-pins (yeah, yeah,
    2-piston sliding calipers on the VFR...bite me) makes more difference to
    my braking feel than adding the braided SS lines (not that I'm sorry to
    have done that, mind).
    HTH, and good luck with it.
    Later,
    John
    John Johnson, Feb 18, 2006
  4. Ninja Stevie
    OH- Guest
    <snip>
    <snip>
    Sounds like a simple Helicoil job. Go to a good mechanic
    (really good - you already found out brake callipers are
    expensive) and there is a very good chance he'll make
    the threads better than new (at a reasonable cost).
    OH-, Feb 18, 2006
  5. Ninja Stevie
    Ron Seiden Guest
    My friends & I have installed oversize bleed screws in more than a few
    calipers (it's always fun to discover you need two or three different size
    wrenches -- in a mix of English & metric -- to do a brake bleeding job). A
    good tap&die set can cure a world of problems, especially when you're
    dealing with threads cut into aluminum, or in places where you're frequently
    loosening & re-tightening -- like bleed screws.... (We eventually stopped
    allowing one guy to put in bolts & screws in delicate places because he had
    big hands & no sense of when a bolt was already stretching...)
    Whenever I've bought an old used vehicle, one of the initial maintenance
    jobs I do or have done is draining the entire brake system & refilling with
    fresh fluid. Brake fluid is hygroscopic and that moisture will, over time,
    rot out any brake system. I just love it when mechanics look at me fisheyed
    when I tell them to do this drain&refill&bleed on a vehicle with sludgey 10+
    year old brake fluid in its system...
    With the cost of new parts, eBay becomes your friend. If you don't find what
    you need at a good enough price, just keep doing the same search week in &
    week out, and eventually almost everything shows up at one price or another
    better things.
    critical area.
    between threads.
    Ron Seiden, Feb 19, 2006
  6. Ninja Stevie
    messenger1 Guest
    sides done.
    calipers.
    Yours Desparately
    Steve
    been there did that ! Get yourself a good quality tap & die set, some
    larger diameter bleeders and its a piece of cake, the aluminum takes threads
    very nicely.
    Tom B
    messenger1, Feb 20, 2006
