Abba Superbike Stand
Discussion in 'UK Motorcycles' started by Christofire, May 14, 2004.
  1. Christofire
    Christofire Guest
    It rocks.
    It's very easy to use, and the only stand I've ever used where there
    wasn't a moment of "is it properly seated, will the bike fall over?"
    For those that haven't seen/used one:
    To use it you slide an L shaped bit of metal under the bike, locating a
    fitting into the swingarm pivot.
    You go round the other side, and fix an upright onto the end of the L
    that has poked through underneath the bike from the other side. A
    couple of twists on a couple of wheels secures it to the frame and the
    bike.
    Wander back round to the left, extend the handle, and pull. I was a
    bit skeptical about the instructions saying do the pulling with one
    hand and guide the handlebars with the other, but it really is that
    easy.
    I'm very pleased with it. Thanks to Hog for recommending it.
  2. Christofire
    Christofire says...
    I have a similar stand that a small engineering firm in Norwich made for
    me in 1998. I saw it in Tinklers M/cs when I picked my new bike up and
    ordered one the next day by mail order. It came with fittings that go
    into the hollow swing arm spindle and has two removeable bars that allow
    the rear of the bike to be pulled down with ratchet straps so both
    wheels can be removed together. Since I bought it I've used it on the
    Firestorm, had new adaptors turned up to suit the ZZR1100C, KR-1 and
    ZZR1100D. The Firestorm fittings are identical to the T/ace as well, so
    I don't have to have new ones made.
    What I really do like is that I don't have to use my back to pull the
    bike up onto the stand, I press down on the bar with my left foot and
    that does the job leaving both hands to steady the bike. Saves an awful
    lot of straining and possible bike damage.
    It cost me 90 quid back then, but is really well made and easy to use
    alone.
    Lozzo, May 14, 2004
