My GT250 frame has gone for powder coating, and I've started work on the forks, I've notice that when I have the lower leg in the vice and rotate the other bit, it is slightly bent!!! one worse than the other, the movement is a bout 3mm and 2mm. Now as the bike steered straight, is this something I should worry about, or is this within any tolerances anywhere ( I see no test for this), and if the bike has whacked something hard enough to slightly bend the tubes, would the frame still be ok?? I couldn't see any cracks or stress marks and as I say it did steer straight and didn't "drop in" on either turn. Peter I just know somone is gonna have fun with this one!!
