A wot??
Discussion in 'Classic Motorbikes' started by Ross Ormiston, Oct 19, 2008.
  1. Hmmmmyesss... but the MZ's six-volt system is damn good, especially the
    headlight.
    The Older Gentleman, Oct 19, 2008
  2. Rusty Hinge 2 wrote:
    Wotcha.
    Well the one I have for sale looks like this
    http://www.moonshiners.org.uk/photographs/2007/06 june/dashers+BSA/dandbsa009.JPG
    Loads of stainless steel, in all the right places. Runs like a B31 should.
    12v electrics, rebuilt dynamo and solid state regulator. All in all, a
    rather shiny example of BSA's finest ( finest what, we ain't saying ).
    Seen here lurking in the place it was born, or what's left of it.
    http://www.moonshiners.org.uk/photographs/2007/06 june/dashers+BSA/dandbsa010.JPG
    If that ain't put you off, then maybe this will ;-)
    http://www.moonshiners.org.uk/video/2007BSA.wmv
    Looking for £ 2500
    My uncle had an old Wolseley with the same nickname, tended to burn it as
    well as leak it.
    ^..^ Lone Wolf, Oct 19, 2008
  3. I'll look at them near the end of the month when I know how many
    minibites I'm in credit on this Vogonfone internot dongle (lite)
    Not sure that the connection is fast enough for a vijo.
    Let's hope I can screw *LOTS* of interest out of the DWP...
    Ah, I had a 6/99 that was that way inclined - never needed to change the
    oil innit.
    Rusty Hinge 2, Oct 20, 2008
  4. When all the connections are tight ant the charging system is the way it
    should be, it's the best 6V system I've encountered.
    I still wanted to 12V it though, for a 12V system would still have been
    better.
    Grimly Curmudgeon, Oct 22, 2008
  5. 12V among other things makes bulb supply easier, also it halves the current
    and reduces I²R losses in cables and connectors by 75%. That's why the
    national grid runs at 33KV, with bigger and higher voltage grids above it,
    for them as don't know.
    Although seriously high voltages have other problems, of course, not least
    the insulation has to work harder and is more prone to break down.
    Austin Shackles, Oct 22, 2008
  6. Ross Ormiston
    Guest Guest
    But it could be a safety factor on dark nights: If you look like
    something out of "Heroes" people tend to keep out of your way.
    Nasty at filling stations though...
    Guest, Oct 22, 2008
  7. Well, on a 6V MZ, you don't have to helicopter alongside it with a
    pressure washer, for a start.
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, Austin Shackles
    So, to summarise, you're saying that a 33KV MZ would be best of all?
    Cool. I'd pay to see that.
    From a distance.
    I dunno, high-tension MZs and CZ plasma-bolts in less than a week.
    Is the Internet great, or *what*?
    Wicked Uncle Nigel, Oct 22, 2008
  9. Ross Ormiston
    You'd be able to. Also, with a headlight powered by 33KV, I imagine
    the chap on the MZ would be able to see you!
    Champ, Oct 22, 2008
  10. Wicked Uncle Nigel wrote:
    Wotcha.
    I'm sure this bloody MZ has internet access.
    Just to prove an electrical point the thing has sat since Saturday with its
    lights on { nothing to do with the clumsy bugger who turned the key one
    click to far }.
    33KV would have been nice - at least the garage would have been warm ;-)
    Needless to say, in true MZ fashion, after a few minutes to "rest and
    recuperate" the thing fired up with no problem. Ah, speaking of fire. Just
    for my entertainment some kind soul decided to set fire to the factory
    behind the pub this evening. Most kind of 'em. Had I have been a bit
    smarter in the thinking department I could have solved the MZ problem once
    and for all.
    http://www.lonewolf.me.uk/LWMEvideo/burnit.AVI
    ^..^ Lone Wolf, Oct 23, 2008
  11. It's crude, slow and dim. Could be it posts as Nige.
    The Older Gentleman, Oct 23, 2008
  12. Ross Ormiston
    Pete Fisher Guest
    Heh, where's that then? Won't help much for this month's particulate air
    pollution monitoring target compliance.
    | Pete Fisher at Home: |
    Pete Fisher, Oct 23, 2008
  13. The message <va16yUnlu6$>
    Electrifying?
    Rusty Hinge 2, Oct 23, 2008
  14. ^..^ Lone Wolf, Oct 23, 2008
