A warped rotor
Discussion in 'Motorbike Technical Discussion' started by Mike W., May 22, 2007.
  1. Mike W.
    Mike W. Guest
    I've had a one in three success with flattening warped rotors on my
    dirtbike. Maybe I wasn't patient enough. I have a new KZ1000P that has a
    serious modulation in braking force as the speed drops below 15mph or so.
    Does anyone have any best practices or suggestions to assure success and
    fewer iterations?
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    71 KG 100 (Hodaka-powered)
  2. Mike W.
    Mark Olson Guest
    Are you sure that the rotor is actually warped? I've had more than one
    bike with the exact symptoms you describe that were fixed by abrading
    off accumulated crud from the rotors.
    Mark Olson, May 22, 2007
  3. A good engineering shop with a hydraulic press should be able to do
    the job just fine. Maybe you're just unlucky.
    chateau.murray, May 22, 2007
  4. What he said. My present BMW had *exactly* that problem.
    The Older Gentleman, May 22, 2007
  5. So your 'cure' is, in fact, for a problem he doesn't have.
  6. Make sure it's really warped and not just cocked and wobbling.
    I had one where the carrier was slightly bent but the rotor was fine
    and simply cocked a little by the bent carrier.
    I was able to mark out the high and low spot on the rotor and then
    correct the wobble by shimming between the carrier and the
    wheel using aluminum foil.
    Rob Kleinschmidt, May 22, 2007
  7. Mike W.
    Mike W. Guest
    Clever.. how did you ascertain wobble vs cocked? That sounds like a very
    small error we're talking about here...
    Thanks to everyone for their help!
    Mike
    Mike W.
    96 XR400
    99 KZ1000P
    70 CT70
    Mike W., May 23, 2007
  8. Mike W.
    Wudsracer Guest
    Hi Mike,
    Before going to any length to fix the problem, I would first remove
    the rotor and make sure if it is warped or not. (after spinning the
    wheel to see if the rotor(s) demonstrates any "wobble".)
    Good to see you again,
    Jim
    PS, Scrape, KW, and I are planning on a "dirt riding meeting" in
    Georgia for the weekend of June 16/17. Come join us.
    http://www.highlandparkresort.com/
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, May 23, 2007
  9. Mike W.
    Mike W. Guest
    Thank you.. I'll track one down.
    Mike
    Mike W.
    96 XR400
    99 KZ1000P - Restored to CHP trim
    99 KZ1000P - No cop stuff.. just nice
    2000 Beta Rev-3
    70 CT70
    Mike W., Jun 3, 2007
  10. Mike W.
    Mike W. Guest
    Hey Jim... thanks for catching up with me on the phone while I waited for
    the guy to come and jump my battery:) I'll try this once I get around to
    KZP-2.
    I have a guest from CA over those days but thank you for the invite...
    we'll connect yet!
    Mike
    Mike W.
    96 XR400
    2000 Beta Rev-3
    70 CT70
