A Tale From The Memoirs: LONG
Discussion in 'UK Motorcycles' started by Pip, Sep 5, 2005.
  1. #He could very well pass for forty-three,
    #In the dusk with the light behind him!
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Sep 5, 2005
    #41
  2. Pip
    Christofire Guest
    I tried, but it was fubared beyond anything I can fix in a few evenings.
    Christofire, Sep 5, 2005
    #42
  3. Pip
    **** made me late for work.
    platypus, Sep 5, 2005
    #43
  4. Pip
    Reading long posts, and having a morning dump, are the two things I
    always leave til *after* I get to the office.
    There are few finer things in live than shitting on company time.
    ogden, Sep 5, 2005
    #44
  5. platypus wrote
    <sigh> Happy days
    steve auvache, Sep 5, 2005
    #45
  6. Neal is that you?
    Paul Corfield, Sep 5, 2005
    #46
  7. Paul Corfield wrote
    Will you people stop this please, that is twice this week that
    particular comparison has been made. It is starting to worry me.
    #47
  8. Pip
    steve auvache says...
    Just think how Neal must be feeling.
    Lozzo, Sep 5, 2005
    #48
  9. Lozzo wrote
    He has feelings?
    #49
  10. Pip
    zymurgy Guest
    HTH (but prolly not ..)
    Paul.
    zymurgy, Sep 5, 2005
    #50
  11. Pip
    Good point.
    Lozzo, Sep 5, 2005
    #51
  12. steve auvache wrote:
    Regulary, he'd have you believe, usually of young ladies iirc.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ VS800 - borked
    Doesnotcompute, Sep 5, 2005
    #52
  13. Pip
    Snippety, snippety, SNIP.
    Splendid stuff, thanks for that.
    Pip Luscher, Sep 5, 2005
    #53
  14. Pip
    Gyp Guest
    In message <>, Pip
    ....But are they still operating or did you actually nail them in the
    end?
    Gyp, Sep 5, 2005
    #54
  15. Pip
    muddy Guest
    heh
    A first Edition Pip in the book case would be nice.
    muddy, Sep 7, 2005
    #55
  16. Pip
    The abbatoir ceased to exist more or less of its own accord when it
    was found not viable to make it comply with European Regulations. The
    by-products plant ceased operations at the same time.
    The practice of furtively and deceitfully disposing of waste on land
    was the subject of a formal Notice under the Control of Pollution Act
    1974 which was a great opportunity to use the term "effluvia".
    It was quite a widespread practice at the time (and still is, in rural
    areas, but rather strictly controlled now) to use sprayers from
    tankers full of waste (from pig farms, septic tanks and other sources)
    to spread a layer across 'fallow' fields as a means of 'fertilising'.
    This was the subject of quite a lot of action in response to
    complaints, and was held to be Prejudicial To Health in many Courts.
    It was never difficult to prove PtoH, as once the Court had seen
    pictures of septic tank waste in particular lying on the surface of a
    field, they wouldn't want to be downwind of that either. Once this
    practice had been held to be antisocial it wasn't difficult to define
    it as "unlicensed disposal of waste products" either.
    More "socially aware" means are used now - feeding the liquid at low
    pressure into flexible 'irrigation' pipes is one, ensuring that the
    liquid just trickles out and is absorbed by the ground quickly,
    without creating the aerosol implicit in spraying.
    There is a much more effective means, that i smuch more high-tech:
    direct ground injection. Using a big four-wheel drive tractor with a
    rear-mounted tank and double rear wheels, large-bore 'needles' are
    pressed into the ground behind the rear wheels and a measured quantity
    of liquid is forced below the soil surface under pressure.
    I was privileged to watch an early demonstration of this technique in
    a field in Somerset. The conditions were proclaimed to be ideal as it
    had rained overnight, softening the ground. It had been fucking
    torrential against my hotel room windows at 03:00, at least.
    Enter Big Green Tractor, Stage Right. Applause from Men In Suits from
    Min of Ag and looks of lust from the tweedy throng. I was a bit hung
    over, so shuffled around a bit to avoid looking into the sun.
    Tractor rolls forward, comes to a smooth halt. Long shiny
    needles appear to the rear, penetrate the ground and the tank pump
    spins up. As needles withdraw, ground surface trembles beneath rear
    wheels and tractor lurches backwards as mud becomes liquid.
    Driver bales out, spraying agricultural oaths. Farmer who owns
    tractor rushes forward, spraying even more agri-oaths at driver, then
    turns and sprays spittle of men from Min of Ag.
    Tractor sinks slowly, until the centres of the impressively-large and
    immaculately-shod rear wheels disappear. Front wheels rear up.
    Soil jellification, they called it. Fucking amusing, I called it.
    Pip, Sep 16, 2005
    #56
  17. Pip
    muddy Guest
    LOL
    muddy, Sep 16, 2005
    #57
  18. Heh. The word "thixotropic" is also used in these instances (I've
    wwaited years to be able to use it on ukrm).
    The Older Gentleman, Sep 16, 2005
    #58
  19. Pip
    Why not just start a thread on DIY/decorating, and work it round to non-drip
    paint?
    platypus, Sep 16, 2005
    #59
  20. Pip
    MikeH Guest
    Cos then it wouldn't be on ukrm?
    MikeH, Sep 16, 2005
    #60
