A Question about the HONDA CB-350
Discussion in 'Motorbike Technical Discussion' started by David Evans, Nov 6, 2008.
  1. David Evans
    David Evans Guest
    Hello, I looking into purchasing another Honda CB350 motorcycle bike.
    I use to own a CB350 a long time ago and right after I purchase the
    bike it started to develop electrical system problems with the battery
    and/or the voltage regulator. Is there a real simple way to fully
    inspect the bike electrical system? spoke with person wishing to sell
    the bike and of course she has agreed to allow me to fully inspect the
    bike prior to purchasing it . I intend to create a flight check off
    list of all of the pertinent items that I must inspect and how to
    inspect on this bike before I purchase it. You know what they say, An
    ounce of prevention, is worth a pound of cure. I am familiarity in
    using a digital multi-meter, a Fluke 83. However I want to make sure
    that I am thoroughly and completely inspect this motorcycle before I
    purchase it. Any helpful comments would be greatly appreciated.
    My Email Address:
    www.davidevans.google.pages.com/dle
  2. David Evans
    . Guest
    1. Get real.
    The CB350 is so old it can no longer be regarded as a consumer
    appliance.
    If you wind up buying it, you can say, "Look at me! I'm a 40 year-old
    Pile of Honda!"
    You can expect it to be unreliable, a Sunday-go-to-the-hangout ride,
    and you're going to have to work on it and you'll have problems
    getting parts, and you can probably expect to have to truck it home
    occasionally.
    Why bug the owner with a nit-picky inspection? If the price fits your
    finances, buy it.
    Or don't buy it.
    ., Nov 6, 2008
  3. What year are we dealing with here?
    You will not be able to do a decent electrical system test unless the
    bike has a charged battery, and if it hasn't been regularly ridden it likely
    will not have a charged battery, or even a battery that is chargable at all.
    The best would be to bring a fully charged motorcycle battery with you,
    then -jump the bike- with the old battery, since it may take many minutes
    of cranking on it to get it to fire and you do not want to wear down the
    old battery. Once it fires, put in your charged battery, then run it.
    With the bike turned off, you should see 12 volts or a little above at
    the battery terminals.
    With the bike on and headlights on but not running, you should see
    close to 12, maybe 11.5 at the battery terminals.
    With the bike on and running with headlights on you should see 13.8
    or 14 v at the battery terminals.
    This is just a basic charging system test. If the bike does not pass then
    I would not rule it out - since often, such problems are easily fixed -
    but I would definitely seek a price drop.
    Of course, check all switches for correct functioning and all lights for
    correct functioning. If the owner claims it just has a burnt out lightbulb
    in a socket, remove the bulb and make sure there's power with a
    12v test light when the light is supposed to be on.
    Ted
    Ted Mittelstaedt, Nov 7, 2008
  4. David Evans
    TOG@Toil Guest
    As others have said: it's an old, old bike and unless it's been
    beautifully kept and/or restored, you shouldn't expect the world.
    Most important check - is it charging? That's been covered.
    For the rest, just check that every electrical item works (lights,
    horn, indicators, brake lights, and that's about it). If any item
    isn't working, but the bike is charging OK, it's only likely to be a
    broken bulb or wire.
    For the rest, engine components for the 350 twin are readily
    available, still, as are all service items like brakes, chains,
    sprockets, etc. There are plenty of aftermarket parts about. Hard-to-
    find stuff will include things like side panels, fuel tank, tinware...
    but it all turns up on Ebay sooner or later.
    Walk away if the engine's rattling, smoking or leaking oil. If it
    doesn't run at all... your call.
    TOG@Toil, Nov 7, 2008
  5. Much less, actually. NRP Carburettors: http://www.nrp-carbs.co.uk
    CB350 diaphragms: £28.50 each, so $90 the pair, plus shipping. I've used
    this company to put new diaphragms onto a Z400 twin's carbs. They do a
    super job.
    The Older Gentleman, Nov 7, 2008
  6. David Evans
    paul c Guest
    As much nostalgia as I have for those old 350's (when they were new, all
    I could afford was a second-hand S90), I'd agree with the above. It
    might be an enjoyable labour of love but not likely a daily driver.
    Just my two cents, there might be a rare exception that was hardly
    ridden but babied and well stored.
    If it hasn't been started lately, I would try to turn the engine by hand
    first and listen carefully and if that is hard to do at least put it in
    a high gear and roll it a few feet.
    paul c, Nov 7, 2008
