A new weave/wobble....
Discussion in 'Motorbike Technical Discussion' started by Scott, May 28, 2009.
  1. Scott
    TOG@Toil Guest
    I'm interested now. Run-flat tyres for cars, yes, for bikes,
    Bridgestone's website doesn't seem to mention them. Nor did the link
    you posted. So where are they?
    TOG@Toil, May 29, 2009
    #41
  2. Scott
    Bob Scott Guest
    That's why I gave up on my last VFR - it cost more for the chain n
    sprox, 2 tyres, 3 discs n pads, new fork leg, new fork seals and wheel
    bearings it needed than the thing was worth so I sold it to a mate for
    "spares or repairs".
    Bought myself an Aprilia to replace it. Within 1k miles it had needed a
    new brake disc, new fork seal & a pair of silencers. Sigh.
    Bob Scott, May 29, 2009
    #42
  3. Scott
    M.Badger Guest
    Gentle opening of the throttle as soon as the bike is turned extends the
    rear suspension. It also helps alleviate any instability effects from the
    rear wheel attempting to slow down. In short, and none too accurately, it
    give the back end something to do. It can help mask worn dampers, but will
    not mask worn S/A bearings or wheel bearings. Helps to isolate a few
    things, and is a good thing generally.
    Dunno about your bike in particular, but crushed bearing spacers can be a
    pain in the arse as the effect doesn't seem at first linked to the cause.
    BTDTGTTS.
    The chain is at its tightest when there is a straight line between the
    output shaft centre, the S/A bearing centre and the rear axle centre. Most
    chain manufacturers recommend approx 1 inch at this point. On a twin shock,
    it is easy to do using the mainstand and a luggage strap. Unbolt the
    shocks, luggage strap over the seat and wind until all lines up. Set 1 inch
    freeplay, bolt back together and measure the freeplay with the arm in
    its 'running' position. Voila. You now know how much the chain should lift
    when it is set correctly.
    A too tight chain will affect the suspension as the cornering loads increase
    and that arm comes in line. Again, a little throttle to extend the rear
    will allow the suspension to work, and as its working against the engine
    now, some semblance of stability is restored.
    On an older bike, you may find that lots of these little niggles mount up to
    a general feeling of unease as things wear. Most are cheap to check, some
    are cheap to sort. A sunny days worth of furtling and going over the bike
    is a pleasant enough way to waste a day.
    M.Badger, May 29, 2009
    #43
  4. Scott
    ian field Guest
    Its a bit of a chore - but so is hellicoiling all the stripped threads on
    the engine casing bolt holes.
    ian field, May 29, 2009
    #44
  5. Scott
    ian field Guest
    I've put a countersunk set-screw through holed stroker pistons - a couple of
    times, the trick is to split the threaded end with a chisel so the nut
    doesn't vibrate loose.
    The first was a Yam 50 that I carried on thrashing till the big end let go,
    the second was a CZ250 that I'd been using for courier riding, it didn't
    handle too well after I welded an XS250 front end on so I sold it to a gang
    of kids for £5 to ride over the fields.
    #45
  6. Scott
    Who Me? Guest
    Forgot about that.......hahahaha....ouch; really NOT funny, but somewhat
    entertaining none the less !!
    Who Me?, May 29, 2009
    #46
  7. Scott
    Schiffner Guest
    Liar, it wont weave at all. BTDT anyway you don't do ANY preventative
    maintinence at all so what would YOU a known pervert and racist know
    about this if it wasn't on wiki?
    Well chickenhawk?
    Schiffner, May 30, 2009
    #47
  8. Scott
    Schiffner Guest
    Gee more than you that's for sure. You don't even change brake
    fluid...hell I've built shocks and you have done what exactly?
    I'd rather shit on you and feed it to your racist friends.
    #48
  9. Scott
    Schiffner Guest
    ROTFLMAO you are one stupid ignornat uneducated chickenhawk your piece
    of underage chasing filth.
    I'd rather feed your sorry as to the pigeons at St. Peter's basillica.
    The pope would likely make me a cardinal for such a good and christian
    deed...
    #49
  10. Scott
    Schiffner Guest
    But it does happen...anyway what would a guy FIRED for incompetance
    from Grumman know?
    #50
  11. Scott
    ian field Guest
    There's no rust aft of the engine.
    ian field, May 30, 2009
    #51
  12. Hello. Found them yet?
    The Older Gentleman, May 31, 2009
    #52
