A Morning's Motoring #2
Discussion in 'UK Motorcycles' started by chrisr, Sep 20, 2003.
  1. chrisr
    chrisr Guest
    Having been browsing the UKRM website last night, specifically on exteme
    accelleration techniques[1], I've just been out practicing on a straight,
    empty section of my local disused aerodrome[1]. First gear's fine - wack it
    shut and open again and up it comes, but I really can't get the second gear
    ones working. When I dab the clutch all I get is a scream from the engine
    and then lots of speed. Nice quick way to get to a ton, but not what I was
    after. I'm sitting back in the seat as per instructions - any tips? I wanna
    do it like darsy :(
    [1]Ahem
  2. chrisr
    chrisr Guest
    Bear wrote:
    <snip>
    Thanks for the tips - I'll give it a go later on!
  3. chrisr
    Cane Guest
    Wot Bear said. He knows his onions and I've seen him use this technique to
    great effect.
    I'm fine with power wheelies but I'm still working on the clutch up ones.
    You've just gotta be brave and ags the fucker then flip the clutch.
    Basically you've gotta give it too much thottle than it can cope with, pull
    in the clutch so the rev rise fast, dump the clutch and watch the front come
    up.
    Champ and Daz will hopefully join this thread soon.
    *nice*
    cane [at] ukrm.org | fireblade, r30
    botafo t#50 f#03 YTC #15 bbb #6 pm #6 apostle [kotl] flo#12[with bar]
    New? http://www.ukrm.net/faq/ukrmscbt.html
    Rideout? http://www.horrible.demon.co.uk/botafof/
    "...and I'm not frightened of dying. Anytime will do"
    Cane, Sep 20, 2003
  4. chrisr
    You're having a laugh, aintcha? I mean, I'm no wheelie merchant, not
    even several classes behind your good self, not to mention Vertical
    Daz - but I do enjoy a little loft action from time to time. And the
    Bandit ...
    Once the B12 had a race can fitted and the "wheelie wires"(1) pulled,
    it was an absolute hoot. It wheelied off catseyes on overtakes, so
    much so that I seriously reckon that I passed more cars on one wheel
    than two. Power wheelies from a standstill were de rigeur; OK, not to
    the vertical, but I'd imagine a good couple of feet of air under the
    front wheel - and if I felt a bit keen, hooking second at about 9k rpm
    would see the front come (to me) _right up_.
    Slapping the throttle open in second from 7k rpm would see the front
    lift regularly and it would gently fall back again as the power tailed
    off. Never had the bottle to try it in third deliberately, but there
    were a few off crests in the road in fourth and a remarkable one on
    the N Yorks moors, with the benefit of my overstuffed rucksack on the
    rack, on the day I picked it up ;-) Fifth gear, doing about the ton,
    loving the whole world and his dog, I was - then the road rose up and
    just dropped away - but the front wheel didn't drop.
    I went down the road for about 100 metres, road dropping at 35 degrees
    or so, bike a little above the horizontal, wondering what the **** to
    do at the bottom - where it bottomed and rose up steeply. Just
    relaxed, gripped the tank and let the bike do it for me, was the
    answer. What a fucking hoot. I miss that bike so much ...
    1. The ignition advance restrictor that keeps it quiet for noise
    emissions regs. Pop the connector, gain full power in first and
    second. Allegedly.
    Pip, Sep 20, 2003
  5. chrisr
    what, not wheelie at all, you mean?
    darsy, Sep 21, 2003
  6. chrisr
    Daz Guest
    <snip>
    I'm afraid that IMO clutching it is one thing you can't teach using
    words IYSWIM. What's actually required to do it is really simple,
    flick the clutch and apply plenty of throttle. It's all about timing
    and practice. Oh yeah and a bike with stupid amounts of midrange :eek:)
    One thing that I think may be useful is adjusting the clutch
    correctly. I find that having the biting point set early in the
    levers travel helps loads as you only have to flick it a small amount.
    This is why I think Ben's Bandit was difficult to clutch up as the
    biting point was right back at the bar. This means you need to use
    all four fingers to pull it in so when the front comes up you haven't
    got a good hold on the bars.
    OK, maybe you can put some of it into words. No idea how useful it is
    though!
    Daz
    GSXR1000K2 - Fun
    CB250 - Purpose
    Fazer600 - Bit of both
    CBR600 - Racer
    MRO#26 | FOT#115 | FOF#48 | two#41
    http://www.highsideuk.com
    ukrm at btopenworld dot com
    Daz, Sep 22, 2003
  7. chrisr
    ozmick Guest
    heh, thanks for the tip. Not only is PG a bit of a Don stuntwise,
    he's very good at seeing what you're doing wrong, and getting you to
    correct it. FOF wheelies, no problem, all we need is a carpark and a
    b12.
    ozmick, Sep 22, 2003
  8. chrisr
    ozmick Guest
    Yep PG's the Don when it comes to stunting. Definitely one of those
    "50 motorcycle things to do before you die".
  9. chrisr
    ozmick fascinated us all by saying...
    and a telegraph pole
    Lozzo
    ZZR1100D, GPZ500S, CB250RS
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14.
    www.mjkleathers.com
    Lozzo, Sep 22, 2003
