A mechanically type question thing.
Discussion in 'UK Motorcycles' started by AndrewR, Mar 19, 2005.
  1. AndrewR
    Salad Dodger Guest
    Indeed. Otherwise you'll reassemble it, and wonder where the funny
    clonking noise is coming from ... until you rip the rhs fairing off,
    and decide to bolt the rhs fan housing back onto the bike, using the
    two 10mm bolts you had left over when you thought you'd finished.
    Possibly.
    Salad Dodger, Mar 20, 2005
  2. AndrewR
    AndrewR Guest
    Right, spurred on by the suggestions that it may be plugs and led into a
    happy state of over confidence by the link Pip posted I decided to go for
    it.
    Without a further thought for my future mobility I whipped off the tank and
    air-filter before getting a twitchy ring thinking about how badly wrong it
    could go when it came to getting the carbs off.
    So I left it there until Saturday. Eddie had suggested a trip up t'Hill so
    on Saturday morning I went out and re-assembled the bike. I got it all put
    back together again, turned on the fuel tap and it started pissing petrol
    everywhere. A fairly brief investigation showed that the pipe between the
    tank and the fuel filter had split and, of course, it's a Kawasaki-only
    part.
    So we caged it into Newcastle, ordered the part and, as the bike wasn't
    going anywhere until it arrived in, got some new spark plugs for it.
    I stripped the bike back down and then Eddie wandered round to give me a
    hand with the plugs.
    The first thing we noticed was that you don't actually need to remove the
    carbs to get to the plugs, despire what it says on the web-page. Then we
    found that the air-filter element was totally clogged up with dirt and
    shredded flies. This was obviously making it run a bit rich, which would
    explain the manky state of the old plugs.
    So the plugs were changed (which is reet faff on, because the frame stops
    you getting a socket in easily. You need to use a spark plug socket, then a
    short extension bar, then a universal joint, then a long extension and then
    a rachet and you pretty much have to connect them one-by-one). My new 2.5"
    length of rubber hose arrived in yesterday (at only a pound an inch,
    bargain) and I got a new air-filter element.
    I fitted that lot yesterday and took the bike for a test at lunch-time
    today.
    The original problem is sorted, no new problems have appeared and the bike
    is going better than I can remember it doing for a long time.
    So thanks to all of those who gave advice, thanks to Pip for the pretty good
    web link and thanks to Eddie for his help. I can look forward to my
    track-day now.
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
    AndrewR, Mar 31, 2005
  3. AndrewR
    Eddie Guest
    Still on for a "shake off the cobwebs" run out on Saturday? Clare
    fancied coming along on pillion, so I won't be doing anything stupid,
    but you can still have fun toying with the more-money-than-skill Ducati
    riders.
    Apparently we need to be in Helmsley for ~10:00, which is going to mean
    leaving at something stupid like 8:30; getting up in time for that on s
    a Saturday is going to be something of a shock to the system.
    Eddie, Mar 31, 2005
  4. AndrewR
    And here ends the case for regular servicing.
    Champ, Mar 31, 2005
  5. AndrewR
    AndrewR Guest
    Want to pop round and check my valve clearances for me?
  6. AndrewR
    antonye Guest
    True, but they could also be full of petrol/water gunk which
    won't come out through the drain plugs, especially if they're
    blocked.
    A bit like the carbs off my racebike that I took apart to clean ...
    http://horrible.demon.co.uk/600ss/050311_dd_02.jpg
    antonye, Mar 31, 2005
  7. AndrewR
    mups Guest
    AndrewR says...
    <squints>, they look fine from here.
    mups, Mar 31, 2005
  8. AndrewR
    AndrewR Guest
    Yup, still on for it and I think Mick said he might come along as well.
    Which means he won't.
    Eeek!
  9. AndrewR
    AndrewR Guest
    Don't be fucking stupid, you'll only be able to see one side from where you
    are.
  10. AndrewR
    mups Guest
    AndrewR says...
    <turns 180, squints a bit more>, Humm, the exhaust on number 3 seems to
    have closed up a bit...
    mups, Mar 31, 2005
  11. AndrewR
    Steve Parry Guest
    antonye fumbled, fiddled and fingered:
    Parmesan ? Gorgonzola?
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Mar 31, 2005
  12. AndrewR
    Eddie Guest
    Considering how much fucking about was involved to get at the plugs, I
    really, *really* don't want to know about your valve clearances.
    You got the workshop manual, didn't you?[0] What does it say in there?
    Is it even possible to do it without taking the engine out of the frame?
    [0] In which case, why were we pissing about using instructions off a
    website?[1]
    [1] Ahhh... maybe that was for the Quattro[2], was it?
    [2] R.I.P.
    Eddie, Mar 31, 2005
  13. AndrewR
    Eddie Guest
    My thoughts exactly.
    Well, yes. It might even involve doing something outrageous like making
    sure the bike's ready on Friday night.
    Eddie, Mar 31, 2005
  14. AndrewR
    I thought it looked like rice pudding.
    Champ, Mar 31, 2005
  15. AndrewR
    Oh, it'll definitely be possible without dropping the motor. Might
    involve a bit more fiddling, tho. You'll have to remove tank, airbox
    and carbs, but you'd done all that already. Then it'll just be 6
    bolts for the cam cover.
    Champ, Mar 31, 2005
  16. AndrewR
    AndrewR Guest
    We never actually got the carbs off because we didn't need to and it
    obviously wasn't going to make life any easier.
    Oh well, it's only half-an-hours work to strip that lot off, so I might do
    the clearances.
  17. AndrewR
    AndrewR Guest
    Yes I did.
    I don't know, I haven't even looked.
    Because I knew where the web-site was.
    I've got one of those as well.
  18. AndrewR
    Of course, the technical stuff starts once you get the cam cover
    off....
    Champ, Mar 31, 2005
  19. AndrewR
    Veggie Dave Guest
    Veggie Dave, Mar 31, 2005
  20. AndrewR
    AndrewR Guest
    I'm sorry, the line must be bad ... my monitor has gone all fuzzy and I
    can't read your message.
    Perhaps you could tell Eddie instead.
