a fool and his money...
Discussion in 'Bay Area Bikers' started by Michael Sierchio, Mar 3, 2005.
  1. The neverending project bike, my 2003 749 came home with me
    today, w/new rearsets and an STM Evo 48-tooth slipper clutch.
    The latter item was expensive, but quite amazing -- including
    the tactile feedback in the lever when the slip mechanism is engaging
    on downshift. I'm pretty good at the brake/clutch/blip/shift
    procedure, but this skill may now be obsolete.
    I was thinking about getting a monoposto subframe, there's one
    on Ebay -- Brendan at Munroe said, "it's probably one of the ones
    that cracks and fails." So, I'll live with the steel bipo subframe
    unless or until a composite monocoque solo seat comes along.
  2. Michael Sierchio
    SPROGO1 Guest
    mike,
    could you expain what the slipper clutch does?
    thanks,
    steve r
    SPROGO1, Mar 4, 2005
  3. It reduces the effects of engine braking when downshifting,
    which reduces or eliminates rear wheel hop (which is a wee
    bit disconcerting when entering a turn, since you're already
    busy, probably). It reduces the chances of overrevving under
    decelleration.
    It also increases confidence in the wet.
    See:
    So how does a Ducati style slipper clutch work?
    http://www.performancemotorcycleparts.com/tuning_pages/slipper_clutches.htm
    Michael Sierchio, Mar 4, 2005
  4. The basic idea is a clutch with ramps, so if the wheel is turning more
    force than the engine, the ramps open the clutch and effectively
    disengage the clutch.
    The one in the new Monster adds an additional trick: its a
    "slipper/gripper" clutch: when the engine is putting more force, the
    ramps close the clutch tighter, allowing the clutch to use lighter
    springs (therefore a lighter level action) while stil being effective.
    Bike has a good summary in the March issue.
    Nicholas Weaver, Mar 4, 2005
  5. Michael Sierchio
    Tim Guest
    Slips. When you release it on decel. If the rear tire speed is too great as
    compared to the speed of the countershaft sprocket. Prevents locking the rear
    tire.
    Tim, Mar 4, 2005
  6. Michael Sierchio
    James Clark Guest
    It holds your slippers out of reach of the family dog.
    James Clark, Mar 5, 2005
  7. I probably shouldn't comment because I have never ridden a bike with a
    slipper clutch but I always like to slam it into first from high revs, chirp
    the tires, bounce the back a bit, it's fun and helps clear the intersections
    of errant pedestrians.
    ps Many thanks to the impropmtu stunters and karters yesterday at a certain
    eastside parking lot--quite a show. I was the clown in a pick-up driving
    thru the axle-deep puddles everywhere. I had to close the sunroof! And
    keep an eye out for the guy who cut in a clear bubble in his top-box and
    gives his little doggie a taste of the two-wheeled lifestyle. That was one
    happy dog.
    Later!
    AC
    mentALEXcersize, Mar 6, 2005
  8. Michael Sierchio
    Rich Guest
    Yust yolking, aren't you?
    Rich, Urban Biker
    Rich, Mar 7, 2005
