a few Monkey Bike questions :)
Discussion in 'UK Motorcycles' started by yonnermark, Jun 23, 2006.
  1. yonnermark
    yonnermark Guest
    Hello
    I just bought a ST70 Monkey Bike for £500 but it won't start. See full
    details at ebay item #8075591299
    Described as:
    "1977 restored 05/6 honda st70 monkey bike new shocks new tyres new
    seat new wiring loom . new mud guards.. chally handlebar conversion old
    fold down bars included 6k on the clock works perfect just needs
    battery charge selling as no storage in a mates kitchen alas.. 3months
    mot left. v5 present. good condition"
    I've tried bumping it down the road and it DID crank up for about 5
    seconds several times. Also managed to start it from the kickstart for
    about 5 seconds but then it died out again.
    QUESTIONS:
    1. Do I need to mix oil in with the unleaded?
    2. Does it matter that the battery is flat? Does that affect the engine
    starting?
    3. There is key with an ignition of some kind. What's that all about?
    4. hmmm, not sure what else to ask.
    any general tips to revive a bike that won't start?
    mark
  2. yonnermark
    WavyDavy Guest
    As it has an auto clutch and semi auto box, bumping probably wont work...
    No. It's a 4 stroke
    Yes. get a fully charged 12v battery off anything and wire that in, then try
    to start the bike...
    No idea what you mean. Ignition key is needed to complete the ignition
    circuit.
    Pop a new plug in.
    Check it has fresh, new fuel.
    Check there's a spark using the new plug and kicking over with the plug out,
    but connected and touching and earthing surface, eg the cylinder head
    WavyDavy, Jun 23, 2006
  3. yonnermark
    WavyDavy said...
    ST70s are 6 volt.
    Lozzo, Jun 23, 2006
  4. yonnermark
    Eatmorepies Guest
    Hello
    Described as:
    One I rode in Greece would flood very easily- it wasn't mine so I never
    checked the float level, go for the non-owner method to start with. If you
    had the choke on and started it - then left the choke on - it will be
    flooded. Turn off the fuel, remove the plug. Kick it a few times - possibly
    with the throttle open. Put in a new plug and kick it - it may well start.
    Wait a few seconds and turn on the fuel.
    It that works you may have to sort the float level - or just turn off the
    fuel when you stop and turn it on again after you have started the bike.
    John
    Eatmorepies, Jun 23, 2006
  5. yonnermark
    yonnermark Guest
    It seemed to kind of work. I mean I was able to knock it into 1st very
    easily and it then tried to start (it did start a couple of times when
    bumping but cut out again)
    Cool
    My neighbour thought it was 2-stroke.
    OK, will do that tomorrow. It's actually 6v but yeah I'll sort that out
    tomorrow and try again.
    Right. So it doesn't have a starter motor then? I have to use the
    kickstart everytime then.
    Yep, done that. It was empty but I just put in a full gallon of fresh
    new fuel.
    Yep. Checked that and the spark seems nice and healthy.
    Have also checked that the is pressure by putting a finger over the
    hole where the plug goes and then kicking it. It blew my finger back
    from the hole so I guess that means there is pressure (that was my
    neighbour's idea).
    thanks very much for your time (so far :)
    Mark
  6. yonnermark
    yonnermark Guest
    good to know, thanks.
    That's a question I forgot to ask. Where is the choke on this thing.
    Can't find it, don't know what it looks like :(
    cool, will try that. thanks John
    Mark
    yonnermark, Jun 24, 2006
  7. yonnermark
    Hush.
    The problem is that 6 volt batteries are very hard to find and very
    expensive, and 6V chargers? Forget it.
    No, the best bet is to take two 12 volt batteries and connect them in
    parallel, then to the bike. This will drop the effective voltage to
    six and enable starting. Disconnect before riding off, obviously.
    Pip, Jun 24, 2006
  8. yonnermark
    Pete Fisher Guest
    Eh ? The voltage of the parallel connected 'driver' batteries will still
    be 12 volts won't it - just increased current capacity? Are you talking
    about a 'jump starting' scenario, or leaving them connected for a while
    to effectively charge the 6 volt battery ?
    I think you can get a 6v battery conditioner for about £20, but that is
    expensive for the benefit of a monkey bike I suppose.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Jun 24, 2006
  9. yonnermark
    Eiron Guest
    That is a cruel trick to play on a newby.
    You can't get 6v out of a brace of 12v batteries without major surgery.
    Eiron, Jun 24, 2006
  10. yonnermark
    You have a very strange neighbour. He knows how to do a rough
    compression check, but can't tell the difference between a 2T & a 4T? I
    suggest you move house.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jun 24, 2006
  11. It does, actually. Perfectly.
    The Older Gentleman, Jun 24, 2006
  12. yonnermark
    At least you got the point.
    <sigh>
    Pip, Jun 24, 2006
  13. yonnermark
    Tim Guest
    I have a 6v & 12v trickle jobbie, little switch to swap voltages.
    Oh look AccuMate do one ...
    http://www.bikestop.co.uk/detail.php?id=1373
    not so hard to find :)
    Tim, Jun 24, 2006
  14. yonnermark
    They're not expensive - I paid about £11 for the last MZ one I bought -
    and 6v chargers are easy enough to get. I've got an Accumate (a 6v
    capable sub-Optimate from the same people) was about £30.
    Some cheapy car chargers have "6v motorcycle" switch.
    sweller, Jun 24, 2006
  15. yonnermark
    RealMart Guest
    It's the lever on the side of the carb. From memory, up is on (for cold
    starting) and down is off.
    The ST70 has a device on the petrol filler cap that seals the vent in
    the cap, stopping petrol from spilling out when you put the bike in the
    boot of your car. This also stops air from venting into the top of the
    petrol tank when the engine is running, which in turn stops fuel
    getting out at the bottom and feedin the carb; you need to make sure
    this device (like a wingnut type of thing) is in the right position.
    If in doubt, try starting the bike with fuel tank cap off completely.
    RealMart, Jun 24, 2006
  16. yonnermark
    Mark Goodwin Guest
    UPDATE:
    We got it started. See the video I made here:
    http://www.yonner.co.uk/blog/141/i-bought-a-honda-monkey-bike-st70
    The thing that SEEMED to have fixed it was turning fuel off, taking
    plug out, kicking it a few times, then put plug back in, leave fuel off
    for a while, then turn fuel back and keep kicking. After 2 minutes of
    kicking it started. Then after that it started 1st/2nd kick everytime
    It seems quite slow though. I got top speed of about 25mph according to
    speedo (and it felt about right). Sounds quite healthy I'd say. The
    chap I bought it off said top speed of about 40-50mph. Any comments on
    that anyone?
    Mark Goodwin, Jun 25, 2006
  17. yonnermark
    *WARNING*
    If, like me, you have fond childhood memories of riding an ST70, don't
    watch that video. Those memories will now be forever tarnished by the
    sight of some fucking chav blinged up with a gold necklace.
    <bleaches eyes>
    Krusty.
    Krusty, Jun 25, 2006
  18. It should indeed do about 45mph+. Mind did. Have you got it into top
    gear?
    The Older Gentleman, Jun 25, 2006
  19. yonnermark
    Mark Goodwin Guest
    I thought someone might make a socially ignorant comment like that but
    I know you're only playing so I won't hold it against you. By the way
    I'm the one at the end of the video trying to do the skid.
  20. yonnermark
    Mark Goodwin Guest
    Yeah I'm pretty sure I'm in top gear. It only has 3 gears right?
    I go down one into 1st then up twice into 3rd.
    It revs smoothly througout the whole rev-range. The engine is
    definately 72cc
    thanks again
    mark
