A blast
Discussion in 'UK Motorcycles' started by Pete Fisher, Jan 19, 2007.
  1. Pete Fisher
    Pete Fisher Guest
    Gorgeous day and for once no shopping to do so I blew the cobwebs out of
    the 'Tart' with a blast to the greasy spoon at Quatt.
    Thoroughly enjoyable. Not much traffic around and no 'patrol presence'.
    Good thrape with a Pan at one point on the straight bits but I had the
    better of him on the twisties. He then turned off to take the short
    route whereas I really wanted to blow stretch her legs a bit.
    Much evidence of seriously ****-off big trees having come down across
    the road. The Highways crews had made an excellent job of the clear up
    with very little debris on the road. One particularly huge tree not far
    from Bridgnorth could have been the one that saw off (no pun intended)
    the top man at Birmingham airport apparently.
    When I got to the caff he was there alongside about 10 other bikes.
    Brief statistical survey revealed Beemers to be in the majority.
    Needless to say most of the other riders were silver haired old gimmers
    like me.
    Good run back an at one point caught up a Honda Acccord that was
    pressing on a bit. So much so that he was straying across the double
    white lines to get a good bite at left-handers and I swear I could hear
    some tyre squeel at one point. He turned off soon afterwards
    unfortunately.
    Absolutely nailed it coming up the last bit of national speed limit dual
    carriageway. The 'Tart' does pick up her skirts and rush on well when
    provoked.
    Several static offence detection systems were duly noted and accounted
    for but the cobwebs were well and truly blasted out.
    Off to clean the Nordie now. Hoping the cold wet snap forecast won't
    last too long so that an MoT can be acquired ASAP.
    | Pete Fisher at Home: |
  2. Pete Fisher
    Ballistic Guest
    That's my old hooning ground around there. The Bridgnorth Road (from
    Wolverhampton) was a favourite many years ago, as was attempting our own
    land-speed record on 'The Rabbit Run' (Not sure if that's the correct name
    of it).
    Ballistic, Jan 19, 2007
  3. Pete Fisher
    Pete Fisher Guest
    Oh I know the Rabbit Run. Wombourne to Telford.
    I usually favour the route which takes in 'the sixty bend'. Known as
    that because it used to feature a maximum advised speed limit of 30.
    In the old days there was a lay-by just past it and on Sundays in the
    summer an ice cream van would turn up. Pairs of hopefuls would go back
    up the road a bit towards Stourton, turn round, and attempt a twice the
    limit run. Once too often with the almost inevitable consequences
    unfortunately, and so the lay-by was removed.
  4. Pete Fisher
    raden Guest
    That brings back some memories ...
    raden, Jan 20, 2007
