A bit slow on the uptake
Discussion in 'UK Motorcycles' started by Mo, Jan 29, 2007.
  1. Mo
    Mo Guest
    Reminder to self, don't assume that a plug repaired puncture is good
    for motorway speeds. It's not.
    No harm done fortunately but that's two calls to the AA in 3 days now.
    Mo, Jan 29, 2007
  2. Mo
    First time I've heard of one failing, TBH. Did the repairer indicate
    whether it was an easy repair or a bit of a bodge?
    _______
    Ace, Jan 29, 2007
  3. Mo
    Pete Fisher Guest
    Perhaps it was a DIY job with the sort of kit I carry round (comes with
    sort of 'sparklets' type bulbs for inflation, plugs, adhesive and tool)
    but fortunately have never yet had to use. I would tend to treat that as
    a get you home job only and take it in for a proper repair.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 29, 2007
  4. Mo
    ginge Guest
    Ditto, in fact I've done motorway speeds with a nail still in the tyre,
    and didn't die, so that must be safe too..
    ginge, Jan 29, 2007
  5. If it was a proper mushroom-headed plug done with the tyre off, it
    certainly shouldn't have failed at all.
    I take it this was a self-repair done with one of the small straight
    plugs?
    Grimly Curmudgeon, Jan 29, 2007
  6. Mo
    Ben Guest
    The one in the back tyre of my GSXR1000 was good for the maximum speed
    it was capable of, over a fair distance.
    Ben, Jan 29, 2007
  7. Mo
    Simes Guest
    Pete said:
    I've used them - and then promptly forgotten tney were in there. Fine
    for the rest of the life of the tyre on the Pan they were.
    Simes, Jan 29, 2007
  8. Mo
    Mo Guest
    It was an AA applied rubber plug and it turns out, according to
    Watling tyres in Catford that they had managed to make one hole into
    two, this wasn't repairable so I now have a new back tyre
    Mo, Jan 29, 2007
  9. Mo
    Dentist Guest
    Mo wrote;
    Was this an AA repair at roadside?
    I ask cos I had some involvement with testing the (then) new plug kit
    used by the AA.
    After some proper research, we road-tested the plugs, 10 to a tyre,
    front and rear, on Goldwings (3, I think), plus some volunteer staff
    bikes. They all outlived the tread, or failed with a slow leak within a
    few miles due to faulty fitting. Never heard of a catastrophic failure.
    But we still recommended 60mph/100miles max. before
    inspection/replacement, to be on the safe side.
    It is alleged that I have done 115mph with 10 plugs in a tyre, but I
    categorically deny the many occasions on which this happened
    (allegedly).
    Dentist, Jan 29, 2007
  10. Mo
    Pete Fisher Guest
    As I understand it all insertable from the exterior plugs are not
    necessarily suitable for a permanent repair. If the particular kit used
    claims they are then OK, if not I wouldn't take the risk.
  11. Mo
    Simes Guest
    Pete said:
    The one I used said it was OK for 50 miles at up to 40mph. I used to
    think about that 4000 miles later poodling home at 120.
    Simes, Jan 29, 2007
  12. Mo
    Pete Fisher Guest
    Fair enough. Nothing like the ultimate empirical test. Puts me in mind
    of the "I don't care what it was designed to do, tell me what it can do"
    (paraphrased) line from Aopollo 13.
    Compared to most round here I am probably very risk averse but I don't
    mind pushing the envelope a bit so far as matters under my control are
    concerned. Entrusting my fate to a bit of rubber I have bodged in at
    the side of the road whilst hot and bothered, just to get me home, and
    then grossly exceeding the manufacturers design parameters just doesn't
    give me a buzz somehow.
    Anyway, what make, type of plug and insertion kit was it? Nothing like a
    personal recommendation.
  13. Mo
    Mo Guest
    Yes, it was an AA roadside repair. Now I've had them done in the past
    and they've lasted until I needed a new tyre. I think this may have
    either been badly done or the damage was worse than it seemed. When I
    ran over whatever it was there was quite a bang, when I realised I
    had a puncture, about 3 or 4 miles later I checked and there was no
    visible cause but there was a significant mark in the edge of the
    hugger where the object had been carried round with the tyre then
    ripped back out when it hit the hugger.
    Mo, Jan 29, 2007
  14. Mo
    Simes Guest
    Pete said:
    I can't remember the make - it was one with a slight mushroom on the
    end, you reamed the hole (all from the outside), smeared rubber cement
    on the plug, stretched it with a stretchy thing that came in the kit
    and pushed it into the tyre. Smoke a fag then blow up the tyre and
    ride like the wind.
    Simes, Jan 29, 2007
  15. Mo
    Pete Fisher Guest
    Self vulcanising by the sound of it. Probably more high tech than mine
    (which I have carried round for 10 years).
  16. Mo
    Simes Guest
    vulgarandmischevious said:
    It's essential - without 'Flat-u-power' the tyre would go down. New
    'Farto' puncture repair kits - only available from Simes-u-like plc.
    Simes, Jan 30, 2007
