a bit rare .... Benelli 350 RS
Discussion in 'Classic Motorbikes' started by Hog, Mar 25, 2008.
  1. Hog
    I've never seen one, rather lovely. I emailed the link to Keith in IoM, he
    seems to like Benelli 4's.
    Hog, Mar 25, 2008
  2. Hog
    Steve Parry Guest
    http://tinyurl.com/2pzdmv
    Not seen one of these in years,
    Steve Parry
    Kawasaki ZX12-R <here>
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    07 VW Passat SE Estate for comfort
    www.gwynfryn.co.uk
    Steve Parry, Mar 25, 2008
  3. Hog
    TOG@Toil Guest
    There have been a couple of Benelli 350s on Fleabay in the last few
    months, but I don't recall an RS. That is very pretty. especially with
    the spoked wheels.
    <Looks closer>
    Is that handlebar fairing the same unit as fitted to the Guzzi V50
    Monza? It looks absolutely identical. The clocks are the same, too.
    Not surprising, as De Tomaso owned both companies at the time: there
    were a lot of common parts.
    <Googles>
    Yup, exactly the same units. I bet the forks are the same, as well.
    And the brakes.....
    I'm watching that auction now. Something like that would make a lovely
    pair to the 400 Four.
    TOG@Toil, Mar 25, 2008
  4. Hog
    It pretty much *was* a 400/4, wasn't it? ISTR that the Benelli fours
    of the 70s were re-engineered Hondas. Alos, the Italians has some
    sort of licence/category cut, which meant they got 350 versions of
    some bikes with larger capacity in other markets - I distintly recall
    seeing a Honda 350/4 in Italy in the early 80s.
    Champ, Mar 25, 2008
  5. You're nearly right. The Benelli 500 Four was close to a Honda copy, but
    not an exact copy.
    Both had exactly the same bore and stroke at 56 x 50.6mm, but the
    engines were not identical. I think bore centres were different, and
    obviously the crankcases.
    The Benelli 350 had a bore/stroke of 50 x 44mm. The Honda 400 Four was
    51 x 50mm. In layout, etc etc, the engines were very similar.
    The Honda CB350 Four was the precursor of the 400 Four, and had the same
    stroke but a smaller bore (47mm). To get the 400 Four, they just bored
    the engine out for a capacity of 408cc.
    But there was more to it than that - the 350F had a five-speed box. The
    400F had six speeds. Maybe bigger valves and a hotter cam, but I'd have
    to check and ICBA right now. Other than that, though, the engines were
    effectively identical. They're certainly interchangeable within the
    frames.
    Italy had a licence break at 350cc (still does, I think). Hence things
    like the Guzzi V35 and even the Ducati 350cc parallel twin, But the
    Honda 350cc Four you're thinking of wasn't a sleeved-down 400. It was
    the bike the 400 was developed from. They sold it elsewhere on the
    Continent, and also in the US, but never in the UK.
    The CB350F was styled like the 500 (and the 750). Rather staid, with a
    4/4 exhaust system.
    The Honda 400 Four never sold well in Italy because it was just over the
    350cc limit. In Japan, where they had a 400cc licence break, they sold
    it in 399cc capacity.
    The Older Gentleman, Mar 25, 2008
  6. Hog
    Colin Guest
    I have a Benelli Sport 354. Originally bought it to use the nose
    fairing for
    my Lemon 1 .... Pretty, low, & light compared to other stuff in the
    garage.
    Not common now. Shame, as interesting piece of development history.
    Colin
    Colin, Mar 26, 2008
