A bit more spannering
Discussion in 'UK Motorcycles' started by Gyp, Mar 12, 2011.
  1. Gyp
    Gyp Guest
    A couple of weeks ago, I fitted R&G bungs to the Tiger, and I decided
    this afternoon to wire in the accessory socket and GPS and connect up
    the Scottoiler.
    By the end of the day, the accessory socket was wired up, the GPS was
    wired up but not working and the Scottoiler is still in its box but has
    moved from the hallway to the garage.
    Rather pissed off that it appears that I've got to take the crash bungs
    off every time I want to take off the lower fairing panels as the little
    rad end pieces that the bungs go through have to come off to allow the
    fairing panels to move.
    Ah well, at least it's the easier near-side one that's got to come off
    to allow access to the GPS wiring so I can see if I can resolve the
    problem. I'll have to see if I can find the pinouts for the Garmin 2610
    lead somewhere.
    Gyp, Mar 12, 2011
  2. Gyp
    the OE lead comes with a black wire, red wire and an audio socket. It's not
    rocket science to work out which is 12V & 0V, spkr + & spkr -
    Just in case you need a pretty picture for the hard of thinking[1] here is
    a pdf http://vidar1.tripod.com/garmin_26xx.pdf page 9
    [1] a favoured phrase of a Glaswegian colleague when asked to present stats
    as a pie chart for managers' meetings
    wessie, Mar 12, 2011
  3. Gyp
    Gyp Guest
    Cheers; pins 1 and 2 then
    Our presentations often have subtitles for the hard of thinking. I've
    often fancied a "Thinking Dogs for the Blonde" T-shirt.
    Gyp, Mar 12, 2011
  4. Gyp
    SIRPip Guest
    That pdf's useful, for a lot more than the pinout diagram. Cheers,
    wessie.
    SIRPip, Mar 12, 2011
  5. Gyp
    pretty pictures...
  6. Gyp
    Gyp Guest
    Been out to check and no joy on the lead.
    To add to the fun though I thought I'd check the voltage on the
    accessory socket and as soon as I popped in my probes... something went
    pop under the saddle. No volts and now the optimate (that connects via
    the socket doesn't think the battery's there any more.
    Ho hum. Time to wait for daylight methinks.
    Gyp, Mar 12, 2011
  7. Gyp
    Oh dear. Sounds like you shorted the central 12V terminal to the earth
    casing, blowing the fuse/trip.
    I fitted a euro/hella/DIN plug onto my Garmin lead. The wires are very
    thin so I filled the surplus space in the plug with silicon sealant to
    stop the wires flexing and breaking. Made a good waterproof seal as
    well. 5 years, 4 continental trips and all is well.
  8. Gyp
    Gyp Guest
    Though oddly I was using the optimate extension lead so the pins were well
    shielded. Not sure how I shorted it
    Sounds like a good idea.
    First job tomorrow though is to strip out the original owner's heated
    clothing wiring as it looks shoddy
    Gyp, Mar 12, 2011
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    So, you blew it up, and *his* wiring's shoddy?
    Riiiiiiiight.
    Wicked Uncle Nigel, Mar 12, 2011
  10. Gyp
    A poor workman always blames the previous tool.
    ogden, Mar 12, 2011
  11. Gyp
    Or the manufacturer.
    Andy Bonwick, Mar 13, 2011
  12. Gyp
    Gyp Guest
    It's a fair cop
    Gyp, Mar 13, 2011
  13. Gyp
    Gyp Guest
    Gyp, Mar 13, 2011
  14. Gyp
    SIRPip Guest
    ... are worth a thousand words.
    SIRPip, Mar 13, 2011
  15. Gyp
    SIRPip Guest
    I might well print that and stick it to the garage wall.
  16. Gyp
    I'll just run that by my dissertation supervisor.
    wessie, Mar 13, 2011
  17. Gyp
    SIRPip Guest
    Pah! What do they know?
  18. Gyp
    Gyp Guest
    Ended up being the 1A in-line fuse in the Garmin loom. I'm not overly
    delighted with the end result as I've tied the wires rather than cut
    them down to fit, but it is on and working.
    Gyp, Mar 13, 2011
  19. Gyp
    2 words. The first is "pass"
  20. Gyp
    Gyp Guest
    I ended up leaving the switched supply wire that had been crimped into a
    relay block in place. Odd that the one connection into the loom had been
    done well (so it seems) but the remainder of it was put together with
    cheap crimped terminals.
    I might rework it with solder and heat shrink.
    Gyp, Mar 13, 2011
