A biking revelation...
Discussion in 'UK Motorcycles' started by JackH, Aug 31, 2009.
  1. JackH
    JackH Guest
    ....maybe, anyway.
    For some time now I've been finding bikes overall a bit boring to ride
    etc.
    I just don't seem to get the adrenalin rush from them like I used to,
    and bar a short period of commuting by bike, they've always been
    something for me to get my kicks from.
    The few that have been fun have invariably been painful on the wrists
    when I've gone scratching round twisties etc, and so I've rapidly lost
    interest in those as well.
    So today I had my eyes opened to what might be my biking saviour, and
    it came in the shape of a fairly unlikely candidate... and for reasons
    which aren't all the obvious ones, either.
    I had a ride on the GSX1100G I recently fettled which is owned by my
    dad.
    'Smooth responsive pull away... oodles of power from feck all revs...
    comfy ride... no strain on the wrists', were the first, possibly
    predictable, impressions.
    I had a go on one of these years ago and mentioned in here I was
    thinking of buying it, and I remember being told I'd end up spat off
    into a ditch in fairly short order, as they were, IIRC, 'unwieldy'.
    Well... I found the handling on the one I rode today excellent - it
    tipped into corners a lot more willingly than I expected given the
    long wheelbase and big angle on the rake of the forks, and it soaked
    up mid bend bumps which would have upset some of the other stuff I've
    owned without fuss.
    The one failing was the forks under heavy braking from 'eeek' mph -
    they bottomed out.
    But then given we've not done a fork oil change yet, that may well
    help resolve this, if not completely eliminate the problem given how
    much these weigh.
    In short bar the bottoming out of the forks, I felt a lot more
    confident slinging this around twisties than I do on the Aprilia.
    Opened up down one local carriageway, I quickly became aware of how
    much difference a lack of fairing makes in terms of being pushed back
    by the wind etc, at anything above 90... possibly the saviour of many
    a licence???
    Anyway... overall I really liked it and think maybe I need to revisit
    a B12 etc in the near future... although I don't remember the ones of
    these I've tried in the past dropping into corners anywhere near as
    keenly as this did.
    Has anyone fitted one of those 'bikini' fairings to bikes along these
    lines and found they've made that much difference?
    JackH, Aug 31, 2009
  2. JackH
    A proper old muscle bike would be a lot more fun than a retro styled
    modern one.
    Riding at speed on the limit of the machine is quite something - even
    when that speed seems fairly tame by modern standards.
    Modern tyres have made it pretty easy to get to the machine's limits as
    well.
    It's difficult to describe how thrilling it is wringing the neck of an
    old, well-sorted bike at it's limits.
    Something that can only be experienced once in a while on a track with
    modern machines - even comparatively sedate ones.
    Not IME.
    sweller, Aug 31, 2009
  3. <snip>
    I'm with Sweller. I'd rather hammer an old lardy classic that a
    modern(ish) lardy naked bike. That, or a modern un-lardy naked, like my
    Triumph. Or, indeed, the Bandit you suggested.
    There's more of a feeling of achievement in getting a ShiteOldBike to
    'proceed' at a fair few rate of knots, especially in corners.
    The Older Gentleman, Aug 31, 2009
  4. JackH
    Gyp Guest
    In message
    Don't let the GSX11 fettling go too far...
    http://tiny.cc/1XMDf
    Gyp, Aug 31, 2009
  5. Oooh, that's not nice.
  6. JackH
    Hah. The "fast lorry".
    No, it'll be a pie problem. Rider as well as bike. Get some sticky oil
    in the forks, and a few tuppences on top of the springs and it won't
    bottom any more. Or shed some pies - your call.
    I found a Bandit 1200 to be much the same, but more 'civilised' than the
    GSX. More nimble, certainly, just as comfy, the B12 has better brakes
    but a relatively poor tank range (100 to reserve).
    Fitting a fairing to a B12 makes a lot of difference - not as good as a
    full fairing in terms of weather protection, but it takes the majority
    of the wind blast off the chest and a good bit off the head, too. OTOH,
    it means licence endangerment returns inasmuch as 100+ cruising is very
    much easier than on the naked equivalent.
    If the chosen B12 doesn't drop into corners and you being of the larger
    persuasion, dropping the forks isn't an option - but longer dogbones is.
    I've prolly got a set lying around here (in a box, in a shed) that came
    off my B12S: fitting them made a big difference - more ground clearance
    as the rear is hoisted by a couple of inches which means that the rear
    tyre shoulders became scrubbable (rather than striking sparks off the
    centrestand, collector and leading edge of the can in that order,
    followed by levering the back end off the ground on the can on a tight
    roundabout which was always a bit hairy).
    The higher back end canted the riding position forward a little, but not
    so much as to make it any more wristy - the vibes through the
    comparatively narrow standard bars always numbed my hands in any case
    (largely due to the angle of the bars in relation to each other) - 10
    minutes, little fingers numb. 15 - 20, next two fingers of the right
    hand, 30 minutes and the right hand was numb, left index and thumb stll
    had feeling. This was only for the first section of a given day,
    however: stop for fuel or a fag, let feeling return and go again and I
    only lost the little and next fingers of the right hand for the rest of
    the day. Fine with wider bars and with straighter bars, however.
    Being taller, you'd prolly appreciate the bit of extra room raising the
    rear would give you: I find the riding position hugely comfy and easy on
    the dodgy back, with plenty of space to shift around and ease the numbed
    toes (less of a problem with toes on the pegs rather than riding flat-
    footed) and the standard old-fashioned slabby seat is immensely comfy
    too, if quite <cough> exciting for lady pillions at 5200rpm <cough>.
    Pip, Aug 31, 2009
  7. JackH
    Ye gods. Why _do_ these things get done? Or rather, get started, as
    they never _quite_ seem to get finished.
    And putting both a £599 starting bid and a higher resevre on - what
    the hell's that about?
    Ace, Aug 31, 2009
  8. JackH
    Simon Wilson Guest
    I recently fitted the small Suzuki OEM fairing to my Bandit 600 and
    found it does make a significant difference. I thought I'd be ok on the
    commute on the motorway, and that it would keep my speed down, by not
    having the fairing. Well, it did kinda/sorta achieve the latter, but
    even at relatively low speeds it was way too tiring. I've only had the
    fairing on for a couple of trips so far but it is certainly a lot less
    tiring.
    Simon Wilson, Aug 31, 2009
  9. Great Understatements Of Our Time
    It got to the point where people on French Runs were refusing to
    accompany the B12 owners because they wanted to get somewhere rather
    than spend half an hour droning at 50mph in a desperate search for
    fuel...
  10. *waves*
    Doesnotcompute, Aug 31, 2009
  11. JackH
    JackH Guest
    Well... depends if the old chap goes through with the threat to sell
    it or not.
    If he does, then I'm seriously considering having it off him.
    Hmmm... I've ridden a couple of B12s, and they've felt a lot 'taller',
    and nowhere near as keen to drop into bends as the GSX did.
    Having said that, I last rode a B12 at least five years ago, when
    CBR600s were the greatest bike on earth, in my world at least.
    Fuel wise though... yes, this drinks it as well.
    Not too fussed about weather protection tbh. Pansyfoofoo I may be,
    but I rarely ride in the wet these days unless I have to, IYSWIM.
    Ok... sounds like 'keeping it real' is the better option for me if I
    go down this route.
    No sense of this on the GSX, yesterday... the Aprilia on the other
    hand. ;-)
    Ok, think I may have to try another one in the event the GSX doesn't
    come onto the market any time soon, in that case.
    And maybe an XJR1200 - they've always appealed as well.
    I'd like to try a GSX1400 as well, but they appear to be still in HFM
    territory compared B12s and the like.
    JackH, Aug 31, 2009
  12. JackH
    JackH Guest
    Which do you consider the GSX to be?
    JackH, Aug 31, 2009
  13. JackH
    Yeah, you're right, of course. I was still largely asleep at the time.
    Which is quite a lot for a shortarse like me. I think I had -4mm 'bones
    which put me on tiptoe and made the Bandit turn in very nicely, tyvm.
    Pip, Aug 31, 2009
  14. JackH
    JackH Guest
    Bar a full aftermarket exhaust system, this one is totally standard.
    19k from new as well, so in good original nick throughout really, bar
    a bit of surface rust on the headstock etc.
    Aside from that, when these go the three wheeled route, they normally
    end up with two wheels at the back rather than the front - tis the
    fact they're a shaftie that makes them attractive to perverts of a
    three wheeled persuasion.
    JackH, Aug 31, 2009
  15. JackH
    JackH Guest
    'That never stopped you before'
    JackH, Aug 31, 2009
  16. <Embarrassed look>
    Yeah, fair cop.
  17. JackH
    Modern, retro styled.
  18. JackH
    I'd call it a standard common or garden late 80s/90s UJM. It doesn't
    have retro styling, it's pretty much stock Suzuki fare for the time.
    Lozzo, Aug 31, 2009
  19. JackH
    DR Guest
    Pip posted:
    My K3 gets about 130 to reserve (slightly bigger tank than the pre-00
    version), although it is probably fair to say my riding is not as,
    erm, 'enthusiastic' as yours might be...
    DR, Aug 31, 2009
  20. JackH
    JackH Guest
    From what I've read, they were marketted as a modern retro... in 1991.
    I'm not that familiar with earlier Suzukis, but my take on it is, bar
    the fact it has a monoshock, it's pretty much an old skool bike both
    mechanically and design wise.
    JackH, Aug 31, 2009
