I pranged the 9R a while back, smashing the radiator into a useless bit of metal. I sourced a replacement rad, from a 6R which is very nearly the same. Only a couple of brackets etc different, fits perfectly. Problem is I've fitted it, refilled it and run the bike. Get it up to temp and it starts to blow air into the expansion tank and then empty the radiator of water. All flowing into the expansion tank and out of the vent tube. The only difference that I can see that might be significant is that the pipe on the filler neck that leads to the expansion tank is very slightly smaller than the original. The hose is not a perfectly tight fit, so it could be drawing air in through there. I tried pinching up tight with a jubilee clip, but to no avail. I'm going to try getting a narrower hose, and stretching it at the expansion tank end, which should give an air tight fit. Beyond that I'm stumped. Any suggestions before I get a man in, which I can't really afford to do right now.
