'98 CBR 600 F3 engine uneveness at 4500 rpm
Discussion in 'Motorbike Technical Discussion' started by John, Apr 4, 2004.
  1. John
    John Guest
    Hello,
    I wonder if anyone can help with this problem. The bike starts and
    idles fine. When you bring the rpm to 4000ish and hold,the engine
    sounds uneven, It does sound like it is running on all cylinders.
    We initially suspected unbalanced carbs, but they have been set to
    within 10mm(columns of mercury)of each other.
    Plug wires are 4.8 to 5.6 ohms, new plugs. The bike 22000 km on it. I
    would like to check valve clearences next, but there is not any
    audible ticking. One interesting note, the engine runs the same with
    the throttle pos. sensor connected/disconnected. What's the special
    tool the manual refers to for checking it?
    I don't know if this could have an influence, but it has a
    Vance&Hines titanium pipe.
    To be honest, I am not 100% convinced there is a problem with the
    sound. The owner though is. I guess it could sound smoother, I just
    have notheing to compare it against.
    Cheers'
    John
    John, Apr 4, 2004
