'96 Virago 1100 Special, backfire on deceleration
Discussion in 'Motorbike Technical Discussion' started by Zaphod Beeblebrock, Feb 10, 2007.
  1. This occurs mostly when exiting the highway, going down the ramp. First
    application of throttle after the backfire causes it to "bog out", tickle
    it a little bit and all is well again.
    I bought this machine a few years ago and it has always behaved like this.
    I see that there are a number of knowledgeable people in this group so
    maybe someone can offer an opinion as to whether this just a qiurk of the
    bike that has to be lived with, or if there is a solution for it.
    On another note, is it my imagination or has anyone else noticed decreased
    milage and harder starting with this ethanol crap they're putting in the
    gas these days?
  2. Zaphod Beeblebrock
    Fred W Guest
    Zaphod,
    How are things out in the Galaxy these days?
    There are two kinds of backfiring that can (or will) occur on
    deceleration:
    There is the putt-putt-putt type. Small backfires but many of them.
    These can occur when the mixture is too lean to ignite in the combustion
    chamber until after a few intake strokes and then you get a flash of the
    raw fuel in the exhaust.
    The other type is less frequent, but more severe explosions in the
    exhaust. So maybe only one or two explosion per deceleration instead of
    putt-putt-putt. These occur when the mixture (on trailing throttle) is
    too rich.
    Since the problem is happening only on trailing throttle, you can be
    fairly certain that the culprit is in the pilot circuit of the carb(s).
    Because the pilot circuit is (usually) a fuel passageway, when it gets
    gummed up (partially occluded) it generally causes a lean condition. By
    the way, this is the most common circuit to get gummed up in a carb due
    to the small size. The other symptom you will usually get with this
    condition is that the engine will have a "lean stumble" when cruising at
    small throttle openings. It will feel like it is surging ever so
    slightly and not running quite as smoothly as might be expected. At
    larger throttle openings it will run fine because the pilot is a smaller
    contributor to the total fuel delivered.
    The other possibility is that someone has played around with the pilot
    jet adjustment screws (probably to ameliorate the above situation) and
    have now over-enriched the setting. The bike will run well when
    accelerating and also when cruising when set that way, you just get the
    dreaded deceleration backfiring. Also fuel mileage will be sub-optimal
    but you may not notice.
    The only way to set the pilot screws correctly (assuming the carbs are
    not gunked up) is with an exhaust gas analyzer or a colortune. These
    tools will both allow you to set the optimum fuel mixture at varying
    throttle conditions. The EGA is better but much more $$. A colortune
    can be yours for about $50.
    Either that or just set the pilots too rich and then progressively back
    off until you no longer get the big bang backfires.
    Fred W, Feb 10, 2007
  3. This is the 21st century, Zaphod, and I haven't seen a tickler on a
    Japanese motorcycle since my 1967 250cc roadracer that Japanese Amals
    with remote floats.
    A tickler worked by pushing the carburetor float down, opening the
    float valve and raising the fuel level so high it comes up the
    emulsion tube and floods the throat of the carburetor.
    That was a very crude and polluting system of starting a motorbike
    engine. It had to go.
    You may think that the starting enrichener valve is a tickler, though.
    If you look at the CARBURETOR diagram
    for the XV1100H or XV1100HC Virago on www.partsfish.com or
    www.bikebandit.com, you will see that item # 21 is called "starter
    set".
    "HC" is the model suffix for the California model and it looks like
    the "H" model had a California carburetor too.
    The "starter set" is a small valve that you open manually to bypass
    air around the throttle butterfly. When the valve is open, gasoline is
    sucked straight out of the float bowl, and that richens up the fuel/
    air mixture for starting.
    This system doesn't work worth a damn if the throttle butterfly is
    open even a little, so if you want to "choke" your engine after it
    backfires, be sure to roll off the throttle all the way.
    Back to the CARBURETOR diagram. Item
    # 19 "diaphragm set" is a deceleration valve that is supposed to help
    eliminate backfiring by closing off an air passage in the idle
    circuit.
    My Kawasaki KLR has a deceleration valve like that, but it still farts
    a little on deceleration.
    It's possible that one of the deceleration valves has a torn diaphragm
    or is stuck, but V-twins tend to make louder backfires because of the
    design of the ignition system.
    Motorcycle ignition systems often fire a "waste spark" when one of the
    cylinders is on the exhaust stroke, and the waste spark will light off
    any residual fuel in the cylinder or in the exhaust system.
    Then there is the possibility that your idle jets and idle passages
    are getting plugged up with gum and varnish.
    I recommend running 3 or 4 ounces of Berryman B-12 Chemtool Choke and
    Carburetor Cleaner in a full tank of gasoline through the engine to
    clean out all the gum and varnish.
    Riding the motorcyle at low speeds until the carbs are clean usually
    does the trick, but I have had occasions when I had to remove the
    carbs for stripping and thorough cleaning.
    Stubborn cases require the EPA anti-tamper plug (item # 26 to be
    drilled out so you can remove the idle mixture screws (item # 9),
    underneath the plugs.
    The plugs will be thick brass and you will have to be careful drilling
    a pilot hole in the plug without running your drill into the head of
    the idle mixture screw.
    On the plus side, the EPA plugs are on top of the carburetors so you
    shouldn't have to remove the carbs from the engine to do this routine
    job.
    Screw a small sheetmetal screw into each pilot hole and then pull the
    screw back out with a pair of pliers and the plug will come with it.
    The next step is to carefully turn the idle mixture screws CLOCKWISE
    until they just bottom out in the holes. Count the number of full
    turns and fractions of a turn.
    Write the information down so you won't lose it.
    Since this carburetor has #40 pilot jets ( item # 15 ), the
    idle mixture screws won't be turned very far out, it will probably be
    around 1/2 a turn, maybe less.
    Once you've written the number down, go ahead and unscrew the idle
    mixture screw, saving the tiny spring, washer, and tiny rubber o-ring.
    Then you can squirt aerosol carburetor cleaner down the hole the idle
    mixture screw came out of.
    Then re-install the idle screw with its spring, washer and o-ring and
    turn it in until it just stops turning and back it out the same number
    of turns that you wrote down.
    Then do the other idle mixture screw the same way.
    Really gummed up carburetors require removal and thorough cleaning
    with an aerosol cleaner. Berryman makes B-12 in an aerosol can, as
    does GumOut and STP.
    Any fuel system cleaner that contains "petroleum distillate" is for
    fuel injectors, it won't do the job you want on carburetors.
    If you have the carbs off the engine and the float bowls and
    diapharagm covers off and the vacuum slides removed, you can spray
    aerosol carburetor cleaner through the idle jet and it should come out
    the single hole that is controlled by the idle mixture screw.
    The same idle mixture passage connects with the three transition ports
    that are covered and uncovered by the throttle butterflies, and the
    passage gets air from the pilot air jet which is probably in the
    intake mouth of the carburetor.
    Sometimes the pilot air jet is underneath the rubber vacuum diaphragm,
    though.
    Spraying aerosol carb cleaner into the pilot air jet should cause carb
    cleaner to come out of the idle jet, the idle mixture port, and the
    transition ports.
    If you don't see carb cleaner coming out of all the ports, cover the
    ports that have good flow with your fingers, and then keep spraying
    carb cleaner until you do get flow out of the blocked ports.
    Where amateur mechanics get into trouble with adjusting the idle
    screws on their carbs is that they think that the idle speed should
    keep increasing as they turn the idle screws counterclockwise.
    They go too far and the idle speed actually slows down because the
    mixture gets too rich. So they adjust the master idle knob to get the
    engine to idle at the right speed.
    This opens the throttle butterflies slightly, uncovering the three
    transition ports.
    The transition ports are for acceleration when the motorcycle is
    moving with small amounts of throttle.
    So the amateur mechanic gets those transition ports open at idle and
    the mixture is far too rich, the engine won't idle down.
    When the amateur mechanic turns the master idle knob down, the engine
    will either run or stall, confusing the heck out of him.
    The trick of adjusting idle mixture is to turn the idle mixture screws
    back in a fraction of a turn at a time, and when the idle speed
    increases, turn the master idle knob down a little.
    Then turn the idle mixture screws in a little more, and turn the
    master idle knob down again.
    Like I said before, you're going to wind up with the idle screws
    turned out about 1/2 a turn (or less) from fully closed with those
    large # 40 idle jets.
    Potage St. Germaine, Feb 11, 2007
  4. Yep, that describes it pretty well.
    No "stumble" (yet) so maybe it isn't too badly messed up. I read most of
    the postings back thru Dec and noted a number of posts regarding the
    addition of solvents to clean the carbs. Might be a thought?
    Could be. The bike was repo'd from the previous owner and I have no idea
    whether he messed with the carbs or not. I was getting about 50 mpg (same
    as my wife's XV 535) with regular unleaded, but it seems to be worse with
    this 15% ethanol crap. I first noticed *that* on a bit of a jaunt around
    the country a while back- I fueled up in TN, didn't notice that it was the
    ethanol mix, and was rather dismayed to find I was in need of fuel
    substantially before I had expected to be...and with no idea where or when
    I would see another gas station.
    When my wife and I are on a trip together I carry four one-liter bottles
    of extra fuel because her 535 has a smaller tank, but I didn't have them
    on this trip since I was alone and figured the room and weight was better
    utilized for other supplies. I wasn't too happy at the thought of pushing
    that machine OR leaving it on the side of the road in the TN hill country
    while I searched for more fuel. Luck was on my side that time and I topped
    out on a hill with a gas station at the bottom just about the time I was
    reaching the end of the reserve.
    OK, I'll clean the carbs first and if that doesn't cure it I'll spring for
    one of the analyzers.
    I *was* having the vague notion that perhaps there was a valve
    adjustment/timing problem that was dumping excess fuel into the
    cylinder(s) and then into the exhaust, or on the edge of running too rich
    rather than too lean.
    Thanks for your input. I've made a note of your suggestions and as soon as
    I get a break in the weather I'll check it out. It's so cold the machine
    won't start, too cold to be working on it outside anyway and I don't have
    enough free floor-space to bring it in the house...lol.
    Zaphod Beeblebrock, Feb 11, 2007
  5. Ethanol is an oxygen bearing fuel. It should make your engine run a
    little cleaner during the summer.
    Running cleaner with ethanol would be the same as leaning up your
    jetting slightly.
    Are you talking about carrying gasoline in plastic 1-liter bottles?
    You're a rolling fire bomb.
    I recommend obtaining some kind of auxillary gas tank made of steel,
    with a shut off valve. Then you could attach it securely to a luggage
    rack or sissy bar and run a fuel hose to a T-fitting in the fuel line
    going to the carburetor.
    There is something of truth in that speculation.
    Valves that are too tight won't seal right and you won't get the
    compression you need.
    Tight intake valves allow reverse airflow through the carburetors as
    the piston rises on the compression stroke.
    A carburetor is a dumb device, it doesn't know which way the air is
    flowing, backwards or forwards.
    The carburetor picks up a shot of gasoline when the air is flowing
    backwards, then gets another shot if gas when the air is flowing the
    right way.
    When you read your spark plugs, you might see the indication that the
    engine is running very rich, but you have no power because there's no
    compression.
    OTOH, your intake valves may fail to seat properly because the valve
    guide oil seals are worn out. The engine sucks oil down the valve
    stems and it burns onto the intake valves because they are a lot
    cooler than the exhaust valves.
    The valve heads will have a lot of hard black carbon burned onto them.
    Chevron's Techron additive is supposed to keep carbon from building up
    in the intake tract and on the valves.
    You can do a "shock treatment" to remove carbon by adding about 8
    ounces of Techron Concentrate to a full tank of gasoline
    A real biker would put his extra furniture out in the barn and move
    his motorsickle into the house...
    The last Japanese motorcycle manufacturer to use a choke on their
    carburetors was Kawasaki. I think they gave up on chokes in the late
    1970's.
    Now the "choke" knob is connected to a bypass starting enrichener
    valve in the side of each carburetor. It's like a tiny carburetor
    built into the side of the big carburetor.
    It provides a very rich fuel air mixture for starting. It may be as
    rich as 1 part fuel for every part of air going through the bypass.
    Riders have a lot of trouble starting their engines because they don't
    understand how the bypass starting enrichener works. It's a bypass
    around the throttle that sucks gas right out of the float bowl.
    If you twist the throttle grip while you're trying to start the
    engine. the butterflies open and vacuum decreases and the starting
    enricheners don't work.
    If you're having problems starting your engine, *don't twist the
    throttle grip*, find the master idle knob that adjusts idle speed and
    turn it all the way counterclockwise so the butterflies are completely
    closed.
    Pull the "choke" knob out and start the engine. If you have to play
    with the throttle once the engine fires up, that's fine, you can nurse
    the throttle until the engine warms up and then re-adjust the master
    idle knob so the engine idles at the correct RPM.
    If the engine just won't idle with the "choke" knob pushed all the way
    in, your idle jets are plugged up.
    Trying to ride the motorcycle with the choke knob pulled out and the
    idle jets plugged up is dangerous, you can't control the engine speed
    under those conditions, the engine will idle too fast or stall as you
    change the throttle position.
  6. Eek. I've got a couple of one-litre Sigg metal flasks (google for them)
    that I've used for fuel. Well, they're designed for it.
    The OP makes no mention of plastic so I trust he's used something
    decent.
    The Older Gentleman, Feb 11, 2007
  7. Zaphod Beeblebrock
    Gene Cash Guest
    sigg.ch? Their amazingly shitty website doesn't indicate any gas
    carrying ability. They don't seem to be vented. Of course I could be
    misreading their amazingly shitty website.
    And did I mention their website is amazingly shitty? Steered me right
    away from their product, it did.
    On the other hand, I have carried gas in a 2-liter Pepsi bottle when the
    gas station had no fuel cans. It was only from the station to the bike
    though, and even by that time it had pressurised pretty well. That's
    when I discovered just how incredibly short-legged my NT650 was.
    -gc
    Yes, and after 12 weeks of rehab, you might even stay off the stuff.
    Gene Cash, Feb 11, 2007
  8. Zaphod Beeblebrock
    John Johnson Guest
    Yes, their website is rather uninformative. No, their bottles are not
    vented. This is, however an advantage if the fuel bottle is stored
    _inside_ your backpack, which is the intended/original use: backpacking
    fuel. It's similarly an advantage in many motorcycle applications.
    MSR makes similar bottles (more common in the 'States than Sigg):
    http://mountainsafetyresearch.com/stoves/bottles.asp
    The two biggest advantages that the Sigg/MSR-style fuel bottles have
    over something like a soda-bottle are:
    -they are approved fuel containers (while most here don't care, it can
    make the difference between the station allowing you to fill or not, if
    you have to re-fill on the road)
    -the cap design allows you to open them against the pressure built up,
    while the o-ring (designed to hold fuel!) will seal it well, which may
    not have as reliable a seal.
    This thread has _lots_ of info about people fuel-carrying setups:
    http://www.advrider.com/forums/showthread.php?t=187146&highlight=extra+fu
    el
    <end thread hijack>
    Later,
    John
    John Johnson, Feb 12, 2007
  9. Zaphod Beeblebrock
    Gene Cash Guest
    Ah, OK. I didn't see a fuel bottle at all on the Sigg site, despite
    spending nearly 20 minutes looking.
    Now these can be quite useful, as you say, and I plan to get some. All
    the small plastic fuel cans around here are such odd shapes that they
    don't fit well in my Givi bags.
    Thanks!
    -gc
    Gene Cash, Feb 12, 2007
  10. Zaphod Beeblebrock
    Fred W Guest
    An interesting idea. But if that were the case wouldn't the engine run
    just as rich at open throttle as on trailing? So his back firing and
    poor engine running would be at other than trailing throttle, no?
    It just seems far more likely that the problem is the carbs are out of
    whack.
    Fred W, Feb 12, 2007
  11. My best guess is that the idle circuits are all gummed up, but I
    wanted to answer the OP's theory about valve clearances or valve
    timing.
    Potage St. Germaine, Feb 12, 2007
  12. Zaphod Beeblebrock
    Fred W Guest
    Which one? The former or the latter. If the former (lean), then by all
    means try to clean out the pilot jets (as well as the rest of the carb).
    If the latter (rich) try cranking down (CW) a very small amount on the
    pilot screw(s). You can turn them in gently fully CW until they seat
    and count the turns to see where they are to begin and then adjust them
    in approximately 1/16th turns from the starting position to see if you
    can find a happy place. Make your testing when the engine is fully
    warmed up and actually ride the bike around a while in each position
    before deciding if it's better or worse.
    Or no stumble because it may be the "too rich" condition which doesn't
    have that symptom. If so, you may be a tweak of the pilot jet screws
    from nirvana.
  13. Zaphod Beeblebrock
    John Johnson Guest
    Yeah, I found them...well pictures without descriptions of them... but I
    suspect that was because I knew what I was looking for. It's a shame,
    because Sigg does make some really high-quality stuff. I've been
    impressed with what I've seen.
    Be sure to check out the advrider thread, and look at the pics of the
    guy who straps 4 of those things (the largest size, I think) to the
    outside of his cases (front and bottom of each case)! That's a whole lot
    of extra fuel!
    There's also a couple of other bottles/containers mentioned there, some
    of which comes with pour spouts (a problem with the MSR-style bottle).
    Later,
    John
  14. The latter, when I was printing out your previous notes, I noticed one
    paragraph that I had read too quickly, which seems pretty dead on as a
    misadjustment of the pilot to too rich. I'll probably find that the plug
    has already been drilled out.
    I'm thinking that this is most probably correct.
    Zaphod Beeblebrock, Feb 13, 2007
  15. No, I may do the occasional dumb thing on a bike (not as many as when
    I was younger and thought I was immortal), but that isn't one of them. I
    use lightweight aluminum bottles designed for backpackers to carry the
    white gas for Coleman stoves.
    It's not so much the furniture as the fermenters and brewing equipment. I
    suppose I could do without beer for the winter...oops, I'm sorry, I had a
    temporary bout of insanity there.
  16. I meant "tickling" the throttle- just cracking it open two or three times.
    Usually, after the backfire, a "normal" application of throttle makes it
    act like it's flooded, cracking it open a couple of times straightens it
    out.
    Good info on the carbs, more detailed than the service manual. I've saved
    it for future reference. Thanks.
  17. Have you ever stopped to smell the exhaust pipe for raw gasoline
    fumes? An engine that is running really rich will 8-stroke. The
    cylinders will fire on every other compression stroke, making a sort
    of "br-r-r-ing" or stuttering sound.
    8-stroking could be caused by a sticky float valve that raises the
    fuel level too high, by jet needles that have been raised up too high
    by a previous owner, or idle screws that have been tweaked too far
    open. or by oversized mainjets.
    If you look for the EPA anti-tamper plugs that I mentioned, they would
    be on top of the carburetors above the butterflies, and find they are
    missing, a previous owner probably opened the idle mixture screws too
    far and did the other things that cause an engine to run too rich.
    But the usual problem is that the idle jets and passages get plugged
    up with gum and varnish over a period of time and the owner discovers
    his engine will start and idle but won't accept any throttle and dies.
    That problem sneaks up on the owner over a period of time. He first
    starts noticing the backfiring on deceleration or stalling as he comes
    to a stop.
    There are two types of backfires commonly experienced when the idle
    jets and idle passages get clogged up. One is a "piffle-piffle-SNAP!"
    on deceleration, when the throttle butterflies close, and the engine
    can't get enough fuel to run smoothly.
    The other backfire is a "fart-BANG!" when a lot of fuel accumulates in
    the exhaust system and is lit off by the waste spark that fires with
    the exhaust valve open during the overlap period of the cylinder
    that's not producing power at the moment.
    Riders also notice the sound of backfiring through the carburetors
    when the engine is cold. This is caused by weak valve springs or
    carbon deposits on the valves resulting from leaky valve guide oil
    seals.
    Potage St. Germaine, Feb 14, 2007
