96 & 98 octane
Discussion in 'Australian Motorcycles' started by will_s, Dec 10, 2006.
  1. will_s
    jlittler Guest
    Plausible but I'd have thought the opposite should be true, if the fuel
    charge is taking measurably longer to combust then you are running the
    risk of part of it being blown out the exhaust ports. Maybe it's cam
    timing that means some engines(1) get a benefit and some don't ?
    JL
    (1) where "some engines" equals the remarkably similar specced
    (superficially) engines referenced earlier in the thread
    jlittler, Dec 20, 2006
    #61
  2. will_s
    jlittler Guest
    Sounds quite possible, wish I knew a chemist so we could find out the
    real situation ! :)
    On that basis then, the variables for whether the engine is more or
    less likely to gain a benefit from a higher octane juice would be
    1 compression ratio
    2 stroke length
    3 cam timing
    (or more likely a function of 2 and 3 combined)
    4. relative wear on the engine (blow by)
    5. ?? some sort of calorific measure per gram/cc/ w/v (whatever the
    correct measure is) perhaps - is there a difference in energy value
    between a litre of 91 ULP and 98 UP-ULP ?
    Other parameters ?
    JL
    #62
  3. Well, a bit... I'd say you're clutching at straws there, then I'd think
    about it for a bit...
    I don't _think_ that's it...
    The instantanous cylinder pressure is determined (ignoring complications
    for now) by the volume of the burnt gasses, their temperature, and the
    current volume enclosed by the cylinder/piston positioning (varying over
    time).
    I suspect that both low and high octane fuels end up with pretty much
    the same oxidised gas mixture (they've both fundamentally got the same
    number of Carbon and Hydrogen atoms to turn into CO2 and H2O -
    everything else is pretty minimal by comparison I think), and with
    pretty much the same volume (otherwise carb/FI tuning differences would
    be much more prevalent).
    There's a quite significant (in speed of combustion terms) period where
    the leverage that the piston has on the crank is quite low - for a few
    degrees either side of tdc I don't suppose the cylinder pressure makes
    much difference at all. So long as the air/fuel mix is completely burnt
    by the time you get to 10 degrees past tdc or so, I suspect the integral
    over time of any potential cylinder pressure differences before then
    would approach zero.
    Since we know either sort of fuel burns fast enough to "work" at redline
    rpm, it seems unlikely that the burn isn't fast enough to have pretty
    much happened completely before the crank turns far enough for it to
    make any difference how quickly the cylinder pressure builds, at least
    at the sort of rpms used in typical commuting.
    Nice try, but I'm _pretty_ sure it's not gonna fly...
    big (oh, and whats your current email, IK?)
    Iain Chalmers, Dec 20, 2006
    #63
  4. will_s
    sharkey Guest
    And here's another one: the XLV, when its CDI exciter coils start to
    burn out, starts to get worse mileage and loses some midrange power,
    even though it doesn't actually misfire? Both spark plugs per cylinder
    are still firing, just weakly. Surely a fire is a fire?
    It turns out combustion isn't as simple as all that and the spark energy
    has an effect on how long the combustion spends 'smouldering' before it
    really takes off and starts net releasing energy. So that's how.
    Maybe its similar with this octane nonsense? The XLV seemed to get
    better mileage on premium too ...
    -----sharks
    sharkey, Dec 21, 2006
    #64
  5. Is that definitely whats going on, or your current working hypothesis?
    I'm thinking along the lines of "half burnt out coils = more resistance
    = lower current = weaker magnetic field = longer time for collapsing
    field to reach the spark gap potential = retarded timing = worst
    mileage" as an alternative...
    Admittedly, my previous argument I used against IK about the time and
    leverage issues the piston has around TDC apply equally well to this new
    argument of mine...
    big
    Iain Chalmers, Dec 22, 2006
    #65
  6. will_s
    sharkey Guest
    Working hypothesis. Comes from a fellow on a mailing list who alleges to
    Know About Such Things, but it's untested.
    .... 'cos that's a fairly credible explanation too. When I get the XLV
    running again I might test it. Not sure how long the "collapsing field"
    time is likely to be (for a CDI system) compared to a degree of rotation
    though ...
    And as a bonus, if higher octane fuels gave a lower spark gap potential,
    that might advance a bit, and maybe explain why some bikes seem to run
    better on premium and others seem to get their cases split!
    -----sharks
    sharkey, Dec 22, 2006
    #66
  7. Fouled plugs on my Blackbird twice in 100,000kms. Both times were the
    only times I filled up with Optimax. Used it in my VTR with out a single
    problem.
    Andrew Carruthers, Jan 25, 2007
    #67
