96 & 98 octane
Discussion in 'Australian Motorcycles' started by will_s, Dec 10, 2006.
  1. will_s
    Theo Bekkers Guest
    We're already halfway through harsh week? Time flies!
    Theo
    Theo Bekkers, Dec 13, 2006
    #41
  2. will_s
    Theo Bekkers Guest
    Hammo is having a flashback to a few weeks ago.
    Theo
    #42
  3. will_s
    Nev.. Guest
    I kept track of fuel usage on an XX a few years ago, did approx 3000km
    using only ULP and approx 3000km using only PULP and at the end of that
    the difference in fuel consumption between the two fuels was noticeable
    in the third decimal point. For that reason I only buy 91 octane for my
    bike. However... every few tankfuls I give it a run with PULP to give
    the fuel system a dose of whatever cleaning agents they have added to
    them... After a few thousand km of running only 91 octane a tank or two
    of PULP does make a noticeable difference.
    Nev..
    '04 CBR1100XX
    Nev.., Dec 13, 2006
    #43
  4. will_s
    Hammo Guest
    Of harsh week? It has only just begun!
    Hammo
    Hammo, Dec 14, 2006
    #44
  5. will_s
    Hammo Guest
    The premise is to provide a fuel that has a reduced volatile inhalant level.
    It is the hoped that this will prevent its abuse.
    As to its equivalence with ULP, that is a can of worms I'm not going to
    breach.
    Hammo
    Hammo, Dec 14, 2006
    #45
  6. will_s
    IK Guest
    No, Hammo. Marketing, not chemistry.
    IK, Dec 14, 2006
    #46
  7. will_s
    jlittler Guest
    I wish I could find / work out the parameters around which it makes a
    difference - the obvious/intuitive ones(1) don't seem to correlate real
    well. For example the TRX ran noticeably better mileage on 98 PULP (as
    much as an extra 40 or 50Km per tank) particularly under light load
    (highway). Whereas it didn't matter a damn to the Bandit - probably
    would have run the same on Kero. 2 stroke doesn't seem to care, Raptor
    didn't before it was tuned but it was running damn rich so I doubt it
    would be possible to tell. It's been dyno tuned with a tank of PULP and
    I've run the PULP since - fuel economy since the tune has improved
    dramatically (an extra 60 or 70K per tank in mixed highway, scratching
    and a bit of town work, it would seem).
    JL
    (the intuitive ones to me would be compression ratio, HP per cc and
    water vs air/oil cooled)
    jlittler, Dec 14, 2006
    #47
  8. As another data point, the Spada reliably gets an extra 20km to reserve
    on premium (~180km on ulp, ~200km on pulp), the but in Monster it makes
    little or no difference (except that the super-premium fuels like
    optimax make it run worse that regular fuel when the needle jets in the
    carbs are worn and it starts running rich).
    Like you, I don't understand whats going on here, as I understand things
    using fuel with an octane rating higher than you need shouldn't make any
    difference... I used to suspect the Spada had a knock sensor and was
    retarding the ignition timing a little on lower grade fuel, but there's
    no sign or a knock sensor either on the bike or in the wiring diagrams...
    big
    Iain Chalmers, Dec 15, 2006
    #48
  9. will_s
    CrazyCam Guest
    CrazyCam, Dec 15, 2006
    #49
  10. will_s
    IK Guest
    How much grimacing would I induce by suggesting that it might be a
    consequence of the slower-burning higher-octane fuel managing to
    maintain a higher cylinder pressure over more of the power stroke,
    resulting in more work being done by the combusting mixture on the piston?
    IK, Dec 19, 2006
    #50
  11. will_s
    bikerbetty Guest
    Lots of grimacing.... but only from me ... coz you may as well be speaking
    Greek.... one day, however, I will understand....
    betty
    bikerbetty, Dec 19, 2006
    #51
  12. will_s
    IK Guest
    Get Hammo to explain it to you... he is, after all, the chemist...
    IK, Dec 19, 2006
    #52
  13. will_s
    Andy Guest
    I did not know that. Is that a fact or just a though??
    Wouldn't a higher octane fuel burn faster and at a higher intensity, hence
    extra HP ect?
    Just a thought.
    Regards
    Andy
    2001, ZX9R
    Andy, Dec 19, 2006
    #53
  14. will_s
    Moike Guest
    Lots.
    What makes you think that the situation you suggest is likely?
    Assuming there is not significant blow-by, what would you expect to
    happen to reduce the pressure generated by the faster burning fuel as
    the power stroke progresses? As long as the faster-burning fuel doesn't
    cause pre-ignition, there should be no problem.
    Moike
    I am not a chemist.
    Moike, Dec 19, 2006
    #54
  15. will_s
    Hammo Guest
    ......anyway, we have videos to watch, don't we Mike!
    Hammo
    is that cos it's denser?
    Hammo, Dec 19, 2006
    #55
  16. will_s
    IK Guest
    Primary objective achieved, then.
    Absolutely fucking nothing...
    A greater proportion of the fuel being used up by the time the piston
    comes around to a given position on the power stroke. The lower-octane
    fuel burns more intensely to begin with, when there's lots of it, then
    tapers off as it's used up, while the slower-burning, higher-octane
    fuel, manages to maintain a higher reaction rate at later stages of the
    power stroke.
    The total work done by the combusting mixture is, give or take a
    simplification, an integral over the full cycle of cylinder
    pressure(which is time-depentend) multiplied by the piston surface area.
    If the pressure manages to drop off less with time, there'd end up
    being more work done on the piston over the full cycle even if the peak
    pressure achieved is lower than with a lower-octane, faster-burning fuel...
    ....still making everything up, of course. :)
    IK, Dec 19, 2006
    #56
  17. will_s
    IK Guest
    I was going to say it would be because there are more carbon-carbon
    bonds to break (how *does* an alkane molecule burn; does it snap in
    half, or do the carbons start breaking off at one end first?), but, once
    again... you're the chemist. You tell us. I'm making this up as I go along.
    IK, Dec 19, 2006
    #57
  18. will_s
    G-S Guest
    Hammo Dense? Never....
    G-S
    G-S, Dec 19, 2006
    #58
  19. will_s
    Theo Bekkers Guest
    Nah, couldn't be.
    Theo
    Theo Bekkers, Dec 19, 2006
    #59
  20. will_s
    Theo Bekkers Guest
    Who?
    Theo
    #60
