93 katana 750 running like doodoo
Discussion in 'Motorbike Technical Discussion' started by Rusty, May 26, 2004.
  1. hehe...mine does too...guess i am getting old....getting ready to
    plant my butt on that machine right now....woohooo...
    JT
    Joey Tribiani, May 29, 2004
  2. my tank is squeaking...so i may pull it just to find out why it is
    vibrating....make sure the front rubber mount is okay, etc...when i
    do, i will snap some pics...
    JT
  3. Rusty
    Charlie Gary Guest
    Probably not, but my thoughts towards a motorcycle are usually formulated
    with a "daily-rider" mindset. :)
    Later,
    Charlie
    Fix the e-mail address and it will get to me
    There are about 100 different sorts of insects in Mexico that some people
    eat on purpose.
    Charlie Gary, May 29, 2004
  4. that is a wonderful mindset....i got to ride my bike today...was very
    enjoyable...took it to a back road(way back in the woods..hehe)...was
    a good ride...i enjoy this old bike...actually i just enjoy riding a
    motorcycle, and wish i could do it more often...here lately I have
    ridden the bike about three times in the last month....totalling about
    100 miles or so....<sigh>
    JT
    Joey Tribiani, May 30, 2004
  5. Rusty
    Rusty Guest
    Well... Yesterday I got a synchronizer and synced them. They were
    about 10-20 mm off from each other. After syncing it ran fine, idled
    smooth on the stand until I rode it about 4 blocks then it refused to
    idle and power dropped.
    So today I bottomed the mixture screws, backed them out two turns
    each. It ran fine sitting on the centerstand. Took it about 4 blocks
    and it refused to idle and acceleration died.
    I'm beginning to think I've got bigger problems, like scored pistons
    or something else that's coming into play after the engine heats up.
    Any thoughts?
    Rusty, Jun 13, 2004
  6. Rusty
    Charlie Gary Guest
    Rusty wrote:
    Fuel starvation?
    Here's another fun one to think about- an electronic crank sensor that fails
    when heated, taking away the timing reference for the coils.
    Charlie Gary, Jun 13, 2004
  7. Rusty
    PQ Guest
    Idling fine requires very little gas. Drive 4 blocks and then acceleration
    dies sounds like limited/restricted fuel flow.
    1) Check for clogged fuel filter (if bike has one)
    2) Pinched or kinked fuel line-limits flow to carb, idles fine then
    accelerates and as flow is limited bike dies or loses power as it starves
    for gas.
    3) Vacuum lock in the tank. As fuel goes out, air must enter the tank or a
    vacuum is created.
    If the vacuum is strong enough fuel will not flow into the carbs and bike
    dies. You stop, open tank to check gas, air enters, fuel flow restored.
    All of the above would have somewhat similar symptoms to what u have
    experienced.
    PQ
    PQ, Jun 13, 2004
  8. Rusty
    Rusty Guest
    After syncing I installed a fuel filter in each line and put in a
    couple of peices of car hose to extend them between the petcock and
    the filters but there're no kinks.
    I thought about trying to clean the screen on the petcock but fuel
    flows freely at both outputs.
    float adjustment?
    Consensus is still a fuel problem? all else being equal and unknowns
    remaining unknown?
    I guess I'll try and track down some needle valves and floats this
    week and try to rebuild 'em next week.
    Anyone know a line on "rebuild kit"s ? The local Suzuki dealer would
    only sell me individual parts (like O-rings for $4...).
    Rusty, Jun 14, 2004
  9. Rusty
    Diablo Guest
    Rusty wrote:
    :: (krusty kritter) wrote in message
    :: :::: From: "PQ"
    :::: 2) Pinched or kinked fuel line-limits flow to carb, idles fine then
    ::: accelerates and as flow is limited bike dies or loses power as it
    ::: starves for gas.
    ::: I experienced that problem when I bought a set of used carburetors.
    ::: The seller had installed a piece of thick-walled automotive fuel
    ::: line instead of motorcycle fuel hose...
    ::: The fuel line kinked and severely restricted the flow of gas to the
    ::: carbs...
    ::: This problem drove me bananas for about three weeks...
    ::: # * 0 * #
    :: After syncing I installed a fuel filter in each line and put in a
    :: couple of peices of car hose to extend them between the petcock and
    :: the filters but there're no kinks.
    :: I thought about trying to clean the screen on the petcock but fuel
    :: flows freely at both outputs.
    :: float adjustment?
    :: Consensus is still a fuel problem? all else being equal and unknowns
    :: remaining unknown?
    :: I guess I'll try and track down some needle valves and floats this
    :: week and try to rebuild 'em next week.
    :: Anyone know a line on "rebuild kit"s ? The local Suzuki dealer would
    :: only sell me individual parts (like O-rings for $4...).
    There are several dealers on ebay that sell complete rebuild kits
    Diablo, Jun 14, 2004
