91 Yamaha FZR600 transmission issues
Discussion in 'Motorbike Technical Discussion' started by jamison, Sep 12, 2005.
  1. jamison
    jamison Guest
    My '91 FZR600 has had transmission issues ever since I bought it. When
    accelerating fairly hard in second gear, it will sometimes pop out of gear
    and into neutral (which is a big shock when you are expecting a speed hit
    but it jerks forward, out of gear). What is the likely cause? If it is an
    internal issue like a stripped gear or something, do the engine cases
    require being opened to get to the tranny? Any insight I can get is
    appreciated.
  2. Register at www.partsfish.com so you can look at the TRANSMISSION fiche
    and see what I'm talking about. There will also be a fiche for the
    shifter mechanism.
    It's just about impossible to strip the teeth off of a gear in a
    motorcycle transmission, because all the teeth are meshed all the time.
    Actual engagement of any given gear is accomplished by sliding one of a
    pair of meshed gears *sideways* so projecting metal pegs called "dogs"
    slide into slots on an adjacent gear. Yamahas have small dogs on the
    gears, go easy on the powershifting.
    If you abuse your transmission, power shifting at high RPM, you can
    wear the shifter dogs so they are rounded off on on side, and the dogs
    disengage by themselves.
    The fix for this is to remove the engine, split the cases and install a
    new gear. But I have heard of motorcycles where it was possible to
    remove the screws from the plate behind the countershaft sprocket and
    slide the countershaft out of the transmission. I dunno if you can do
    that on an FZR600...
    Some racers will take a grinder to the dogs and undercut them at an
    angle so they will remain engaged under power.
    The mechanism that slides gears sideways is called a shifter drum.
    There's a linkage that rotates this cylindrical drum that has strange
    patterns of grooves in it. Pegs on the ends of the shifter forks have
    to follow the grooves, and the forked end of the shifter forks engage
    slots on the sliding gears.
    There is a detent mechanism on the end of the shifter drum which
    engages a star-shaped cam. The detent mechanism HOLDS the shifter drum
    in the correct position for the gear you want to be in. The detent
    mechanism may be a spring and ball bearing, or there might be an arm
    with a spring and a roller.
    It's possible that the detent mechanism is not engaging the star-shaped
    cam correctly.
    The star-shaped cam is symmetrically shaped, each of the peaks is the
    same spacing as the valleys that the detent ball or roller must go
    into. One of the valleys is neutral, the other valleys are each for one
    of the six gear positions.
    Since the valley for neutral must be between the valley on the
    star-shaped cam for first and second, this means your foot must move
    twice as far to shift from first to second as it has to move from
    second to third and so on...
    So, your popping out of gear problem might just be because you're not
    moving you foot far enough to get the detent ball or roller to drop
    into the valley for second gear, maybe the detent is still on the peak
    of the cam and the spring drives the shifter drum back toward
    neutral...
    Try moving your foot further when you shift from first to second...
    krusty kritter, Sep 12, 2005
  3. Worn selector dogs. Common prob on the FZR600.
    Engine and gearbox strip time. Not cheap.
    The Older Gentleman, Sep 12, 2005
