86 gpz 600
Discussion in 'Motorbike Technical Discussion' started by Wrenchtamer, Sep 6, 2008.
  1. Wrenchtamer
    Wrenchtamer Guest
    I just bought this bike and It idles (badly) but wont run. If I try
    to give it throttle it dies immediately and will only idle for a short
    time before dying out. I assumed the carbs were shot so I tried to
    bypass them for diagnostic purposes by sprating carb cleaner in the
    intake and it didnt pep up at all. It has spark, I checked to see
    that the coils were pulsing with my power probe and then checked each
    plug to make sure they were all firing and they are which leads me to
    believe this could be a compression issue. Am I missing something?
    I've read a little bit about the cam chains going bad on these bikes
    but I dont hear any hideous noises when it idles.... I'm an auto
    tech but this is my first liquid cooled bike and I suspect someone
    might have some input for me. Any help would be appreciated.
  2. I doubt that the carbs are "shot", as you put it. They are just
    plugged up internally.
    Your motorcycle has diaphragm carbs that take control of the high
    speed circuit away from the vagaries of the rider's frisky wrist.
    The carbs were made this way to reduce air pollution.
    The idle circuits have small idle jets, concealed idle mixture screws,
    and very tiny idle ports and passages which are easily plugged up by
    gum and varnish from evaporated gasoline.
    Since I have run down how to clean out diaphragm carburetors a
    bazillion times, I suggest that you google for EPA anti-tamper plugs
    and transition ports and Berryman B12.
    ÃÄÈËÎÐÓÖØÙ, Sep 6, 2008
  3. Wrenchtamer
    Wrenchtamer Guest
    But if it were strictly a carb issue, wouldnt it pep up when I spray
    carb cleaner or some other aerosol fuel into the air box?
    Wrenchtamer, Sep 8, 2008
  4. Wrenchtamer
    Who Me? Guest
    Yes, probably......but all carb. cleaners are NOT good fuels.
    Try ether starting fluid; then you will be proving something.
    Who Me?, Sep 9, 2008
  5. Wrenchtamer
    Ian Singer Guest
    If the jets or passageways are blocked how will the carb cleaner get
    through them to make it pep up?
    Ian Singer
    See my homepage at http://www.iansinger.com
    hosted on http://www.1and1.com/?k_id=10623894
    All genealogy is stored in TMG from http://www.whollygenes.com
    Charts and searching using TNG from http://www.tngsitebuilding.com
    I am near Toronto Canada, can I tell where you are from your reply?
    Ian Singer, Sep 9, 2008
  6. Wrenchtamer
    Wrenchtamer Guest
    I tried an ether based starter fluid, (thrust). The results seemed
    inconclusive. that is, there was no appreciable change in throttle
    response or idle. As I posted before, all plugs are firing. Im
    performing a compression test this afternoon, which should at least
    yield a more definite prognosis. If I have good compression there is
    hope. If not.... There is less hope I guess.
    Wrenchtamer, Sep 9, 2008
  7. Wrenchtamer
    Wrenchtamer Guest
    Got it. the bike had a bad connection at the ecm. the wire that
    grounds the 1 and 4 pulse coil. I was back probing it and the bitch
    fired right up. What a great feeling.
    Wrenchtamer, Sep 10, 2008
