85' Goldwing Throttle Return Problem
Discussion in 'Motorbike Technical Discussion' started by Rick Cantellya, Aug 6, 2004.
  1. My 85' Goldwing GL-1200 came back from the dealer with a problem unrelated
    to what it went in for. When releasing the throttle to shift gears, the
    engine speed lingers where it was and gradually returns to idle after maybe
    4 or 5 seconds rather than immediately dropping towards idle speed. Of
    course, the dealer has NO idea of how this happened and is doing anything he
    can to avoid owning up to it.
    I received a few responses to this question earlier, most of which suggested
    a pinched our bound throttle cable. I should have mentioned that I had
    already been over that and all linkages and return springs are functioning
    properly. I've also been looking for a vacuum line that may have been
    knocked off, but everything looks good.
    Does anybody have a good working knowledge of this system that could explain
    how the idle return mechanism works? I've heard a few people mention vacuum
    assisted return and/or steel piston type mechanisms.
    Please respond to newsgroup only. Thanks in advance.
