84 suzuki gs450l carbs problems
Discussion in 'Motorbike Technical Discussion' started by Cedric, Aug 26, 2003.
  1. Cedric
    Cedric Guest
    I have an 1984 Suzuki GS450L and I'm having some problems. From the reading
    I've made on the net and here it seems it would be a carb problem. My bike
    seems to stumble some times. At low RPMs it will stumble then take off and
    if I keep it at around 4000 to 5000 it will seem like it's running out of
    gas but then take off again. I installed a new air filter a while ago and
    it seemed it was that because I replaced the old one and it stoped... well
    for a while but now it's back and I don't know what to do anymore. Any help
    will be appreciated. And if the carbs need adjusting I would like to know
    how. Thank you in advance.
  2. Cedric
    bornin_67 Guest
    if you've never done carbs before, let a professional do it unless you are
    willing to spend hours in front of a shop manual.
    goto modern motorcycle. tell them to:
    - clean the carbs
    - sync the carbs
    - install a gas filter
    enjoy!
    bornin_67, Aug 27, 2003
  3. Cedric
    Cedric Guest
    One more question before I send my bike in, how much is this gonna cost me?
    Thanks
    Cedric, Aug 27, 2003
  4. Cedric
    Bob May Guest
    I had similar problems with an '86 GS550ES I bought that had been
    sitting for several years.
    The carbs were pretty crudded up. Lots of sediment in the bowls and
    passages. Also, the slides were not sliding up and down nicely. This
    is quite likely the cause of the stumble then take off problem. I
    lapped the slides back into their bores which helped the beast run
    much better. It still doesn't idle well when cold however.
    Bob
    Bob May, Sep 4, 2003
