84 KZ 550 blowing fuses
Discussion in 'Motorbike Technical Discussion' started by comtedelafere, Oct 10, 2006.
  1. I've got an 84 Kawasaki KZ 550 that keeps blowing the first of five
    fuses in the fuse box. The guy I bought it from rode it over here last
    week and I got it started after he left. He's coming over tomorrow to
    look at it, so I'm pretty sure he hasn't done anything underhanded. The
    day after I bought it, it wouldn't start. I had the battery checked,
    and it was depleted. I bought a new one and charged it at home. After
    putting that in the bike, it still wouldn't start. I then noticed the
    first fuse was blown so I replaced the 10A fuse with a 14A one. As soon
    as it made contact with the bike, it blew. I've checked all the wiring
    and can't find a short anywhere. No matter how I do it, if there is a
    fuse in the slot and the battery is hooked up, the fuse blows. Any
    ideas?
    Isaac
  2. It might help us if you told us what the first of the five fuses is
    supposed to take care of. Look at a manual.
    The Older Gentleman, Oct 10, 2006
  3. I've got a Haynes manual that came with the bike. Since it covers so
    many iterations of the model and it's relatives, it's a lot harder to
    read than the automotive Haynes manuals.
    According to the wiring diagram, the first fuse goes to the front of
    the bike to an 'electrical accessory terminal.' Very descriptive.
    Isaac
  4. I bet you're right. Could just be dirt and a short in the ignition
    switch contacts as well.
  5. LOL
    OK, yes, you have a problem :)))
  6. comtedelafere
    durtdog Guest
    You mentioned that there was a 10A fuse in there and you put in a 14A. Does
    your manual say what the circuit's rated for? You mentioned 'accessory', do
    you have any odd switches, old wires hanging out, or anything that looks
    like it was added? Look for any bare cooper wiring anywhere? Finally, if it
    is an "accessory", are you sure it's needed to run the bike? You might be
    barking up the wrong tree.
    durtdog, Oct 11, 2006
  7. comtedelafere
    traddaddy Guest
    They guys at kzrider.com are usually pretty helpful. you might check
    there.
    traddaddy, Oct 11, 2006
  8. comtedelafere
    John Guest
    Get a test light or multimeter and check for 12v at ign coils. If you have
    power there with ign switched on then blown fuse isn't your problem.
    JOhn
    John, Oct 11, 2006
  9. As others have suggested, pull the tank and look at
    the wiring runs under the tank and going into the
    headlight. Also look for any bodges left behind by
    a previous owner. Most likely, you can find it this way.
    If visual inspection doesn't work you really need a wiring
    diagram and a multimeter to check continuity. You'd
    start from the fusebox and disconnect plugs one by
    one making notes of what you were doing and testing
    to see if the short went away. If it went away, the problem
    would likely be in the last thing you unplugged from
    the harness. If it never went away, the problem is
    in the main harness.
    Rob Kleinschmidt, Oct 12, 2006
