'83 Virago 750 Resurection - Question
Discussion in 'Motorbike Technical Discussion' started by virago750, Sep 5, 2004.
  1. virago750
    virago750 Guest
    I have been restoring/resurecting an '83 Virago and am almost done but
    tonight I ran into a problem; The engine runs pretty well.....until you put
    it in gear. Then it dies immediately.
    Unfortunately, I can't find my owners manual, which has the wiring
    diagram.....we just moved you see and I still haven't sorted every thing out
    yet.
    I am wondering if it has anything to do with the switch that won't allow
    the bike to start unless its in neutral. I think this is just for engaging
    the starter but I'm not certain.
    Can anyone offer some good advice/help? It would be most appreciated.
  2. Yes, it is. It'll have a clutch/gear/sidestand interlock.
    The Older Gentleman, Sep 5, 2004
  3. virago750
    virago750 Guest
    Got it. There was a break in the wiring for the kickstand switch.
    Thanks for all of the help!
  4. virago750
    messenger1 Guest
    Can anyone shed some slight on what exactly this interrupt switch does?
    Does it cut power to the coils?
    Tom B
    messenger1, Sep 6, 2004
  5. In essence, yes. It cuts the power to the low tension side of the
    ignition circuit so no power gets fed to the coils, so no spark.
    The Older Gentleman, Sep 6, 2004
