83 Honda Shadow, again
Discussion in 'Motorcycle Technical Discussion' started by t, Jul 18, 2005.
  1. t
    t Guest
    Ok, I need to know if this is part of the problem. I have already
    checked the fuel pump, seems to have adequate output. However, I
    replaced the factory fuel filter (inline, before the pump) with one from
    the local bike shop, but it is a generic, clear fuel filter, not factory
    spec. It only has fuel in the bottom third of the filter. What is
    level of fuel should be visible in the filter?
    Symptoms: I'm trying to adjust my carbs. However, I can't get
    consistent idle. It will idle for a while, then crash on me. I keep
    having to adjust the throttle, since I seem to get runup in RPM when I
    adjust the master idle screw. Am I not getting enough fuel to allow me
    to adjust the idle, and therefore the carbs?
    t, Jul 18, 2005
  2. Clear plastic fuel hoses and clear plastic fuel filters are often only
    part filled with gasoline, making the amateur mechanic wonder whether
    there's a vapor lock, or what the heck is going on.
    You don't want any loops in the fuel lines where you can have bubbles
    form, and the filter should be below the fuel lines and the petcock.
    You might want to disconnect the lowest end of the fuel line and blow
    backwards with the gas cap off. If there is crud in the bottom of the
    gas tank it may blow backwards out of the petcock into the gas tank.
    Then when you allow gasoline to flow back through the filter again, it
    may fill up, and after some running of the engine, that damned air
    bubble will restablish itself! The problem could be crud in the petcock
    again, or a vapor lock in the fuel line and filter...
    Well, if you can't get the air bubble out of the filter, you can try
    the old plastic hose trick to see what the fuel level is inside the
    float bowl while the engine is running...
    Just remove the float bowl drain hose from the spigot on the bottom of
    the float bowl and stick about 6 inches of clear plastic aquarium
    tubing on the spigot. Open up the float bowl drain screw and hold the
    open end of the aquarium tubing up by the float bowl gasket area. The
    fuel level should be withing about a millimeter of that gasket and
    should stay there as the engine idles and the fuel pump keeps replacing
    the fuel that's been burned...
    krusty kritter, Jul 18, 2005
  3. t
    t Guest
    thanks again for the help. I've taken the spark plugs out tonight, and
    they were pretty carbon fouled after a very short time. Dry, black
    coating. I cleaned them off, seemed to dispel the problem with the
    engine falling out on me while trying to tune the carbs. Like I said
    before, I'll get better plugs next paycheck.
    I actually made progress, started about 1.5 turns out, ended around 2.25
    to 2.5 turns out. Don't think I'm quite there, but it was getting late.
    When I rev the throttle quickly, it seems like it is stalling out, but
    when turned slowly, it revs just fine. I'm doing all this from
    sound/smell, since I don't have a good tach or any fancy tools. But
    like you've posted before, I'm trying to learn to do it the right way,
    not just the "procedural" way.
    Likely, I'll start again tomorrow from scratch, now that I have some
    idea what I am looking for.
    As far as the gas tank, I've pulled the main tank and cleaned it, but
    the secondary tank hasn't been pulled. I'm sure it has some build up in
    it, but it is not as easy to pull off as the main tank. To the
    outsiders, yes, it has two separate tanks.
    t, Jul 18, 2005
  4. t
    mike Guest
    krusty kritter wrote:
    snip
    Could you be a little more specific on this technique. The gasket line
    is about 45 degrees off horizontal on my 83 VT-500C Shadow.
    How can we tell where on the gasket to make the measurement?
    For making the relative measurement, you can use a much longer tube
    taped to the gas tank and a big paper clamp on the end.
    You can go down the road at speed, open the clamp to let the level
    stabilize in the tubing, close the clamp, then stop to safely
    read what the level was at speed.
    Thanks, mike
    Return address is VALID but some sites block emails
    with links. Delete this sig when replying.
    Wanted, PCMCIA SCSI Card for HP m820 CDRW.
    FS 500MHz Tek DSOscilloscope TDS540 Make Offer
    Wanted 12" LCD for Compaq Armada 7770MT.
    Bunch of stuff For Sale and Wanted at the link below.
    MAKE THE OBVIOUS CHANGES TO THE LINK
    ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
    mike, Jul 18, 2005
  5. My Haynes manual shows how measure the fuel level with carbs mounted at
    a 45 degree angle. It seems that there is a reference line molded into
    the bottom of the float bowl on Mikuni semi-downdraft carburetors, so
    the fuel level can be checked with the $pecial Expen$ive Yamaha $ervice
    tool.
    The tool is essentially a piece of flexible clear plastic tubing but it
    has another piece of clear tubing in the end that's calibrated in
    millimeters...
