Ok, as posted earlier, I've taken the carbs completely apart, reset the floats and taken the pilot screws out and flushed their channels out. I reset the pilot screws to 2.75 turns out per the manual. Now, as it idles, I have the idle screw turned completely out (not touching). I use the throttle to keep it idling, or else it will quit. I am trying to set the main idle screw while holding the throttle so it will hold the idle on its own. However, when I set the main idle screw, the engine seems to rev up from my throttle idle of around 1000-1100 rpm to around 4000 rpm. When I turn the main idle screw back, the engine eventually comes back from being hung up, then dies. It seems to be an all or nothing deal. I tried to turn the pilot screws in to about 1.5 turns out, still the same deal. Does this mean another breakdown of the carbs to clean out something I missed? Any other explanations?
