'81 GL1100 Vibration
Discussion in 'Motorbike Technical Discussion' started by jlsmed2, May 3, 2004.
  1. jlsmed2
    jlsmed2 Guest
    I recently purchased an '81 GL 1100. on the ride home I noticed a
    fairly severe vibation in the engine/trans when decelerating. It also
    does it when you rev the motor in neutral. The feeling that I get is
    like something is very out of balance, but only when the engine is not
    accelerating. Any input would be appreciated. -Jeff Childs
  2. Chain needs tightening.....
    The Older Gentleman, May 3, 2004
  3. jlsmed2
    Geribaldy Guest
    No chain anywhere on the GL1100 AFAIK
    Geribaldy, May 3, 2004
  4. You sure?
  5. jlsmed2
    Hank Guest
    C'MON TOG, I know you know what a GL is!
    Actually there are a couple chains inside ( primary, starter), but I would
    suspect a worn universal joint, driveshaft spline or bearing( wheel,
    rearend, steering head, swingarm).
    Hank, May 3, 2004
  6. jlsmed2
    Hank Guest
    AAMOF No..................
    Top posted by design. I hate scrolling to read replies
    ----- Original Message -----
    Newsgroups: rec.motorcycles.tech
    Sent: Monday, May 03, 2004 2:51 PM
    Subject: Re: '81 GL1100 Vibration
    Hank, May 3, 2004
  7. Awwww... spoilsport.
  8. my dad has an 81 wing also and his rattles also, but only when
    starting to move. he researched it and found that most all of them
    will rattle a little. something about, if i remember right, the
    primary drive chain. something with the followers i think.
    matt neumiller, May 17, 2004
