79 KZ1000 ST
Discussion in 'Motorcycle Technical Discussion' started by john smith, Sep 1, 2005.
  1. john smith
    john smith Guest
    I have a 79 KZ1000 ST with what I believe to be a bad/weak coil (or maybe
    just the wires) Problem is that the wires are not removable. Now, I like
    to tinker, and have considered slowly cutting away the housing near where
    the spark plug wires enter the coil, and see how its connected. Has anybody
    attempted such a thing? Its mainly out of cheapness, and unwillingness to
    drop $150.00 on a new set of coils, if I dont know it will fix my problem!
  2. I knew I a guy who bought a Honda CB500 at a yard sale. It had 8 bent
    valves from being over-revved horribly and the previous owner had also
    cut the wires off the coils, so this guy stuck ordinary sewing pins
    into the coils and cut their heads off and slid new metal core spark
    plug wires down over the pins.
    The wires fell off on the first ride...
    But, what does the spark you're getting now look like? If it jumps
    1/4th of an inch with a blue spark and does that every other turn of
    the engine, you have plenty of spark to fire the mixture (at least at
    idle).
    What symptoms does your engine exhibit when running at high RPM or with
    lots of throttle?
    Your KZ1000 ST has electronic ignition with a pulser coil to send a
    signal to the electronic ignition box and there is a ballast resistor
    hidden somewhere in the wiring harness.
    Check that ballast out to see if it's making good connections.
    In the 1950's and 1960's cars used ballast resistors mounted on the
    firewall in the engine compartment to reduce the 12 volt battery
    voltage down to 5 volts after starting the engine. The engine got a
    hotter spark for starting, then ran on less current when the resistor
    heated up.
    So, if you were to buy a stock coil for your KZ1000, you'd probably be
    buying a 6 volt coil which would have about 1.5 ohms of primary
    resistance, instead of the 3.0 ohms of a 12 volt coil. If you use a 12
    volt coil, you need to bypass the ballast resistor. Will the transistor
    ignition unit put up with a 3.0 ohm coil instead of a 1.5 ohm coil?
    Probably.
    I recently saw that www.oldbikebarn.com was selling aftermarket Dyna
    ignition coils, but the purchaser definitely needs to know *which*
    resistance coil to buy...
    krusty kritter, Sep 1, 2005
  3. Aftermarket high-output coils are way cheaper than this and will perform
    better. Have a look in some catalogues.
    The Older Gentleman, Sep 1, 2005
  4. john smith
    Matt Guest
    What symptoms are you having? I just "fixed" my friend's '79 KZ1000
    that was hard starting and stalled under load until warm. We just put
    in new plugs and replaced a couple broken plug caps, so that it runs
    great now. Have you tried simple stuff like that?
    Matt, Sep 2, 2005
  5. john smith
    Matt Guest
    If you are cheap, you won't go hacking up your coils without good reason.
    Matt, Sep 3, 2005
