'79 CB650 carb jetting
Discussion in 'Motorbike Technical Discussion' started by frogliver, Jun 17, 2011.
  1. The carbs were bloody awful on the CB650.
    The Older Gentleman, Jun 18, 2011
  2. frogliver
    Gus Guest
    Hard starting due to lack of ignition system voltage was a problem for
    motorcycles back in the 1970's, so riders learned they had to set
    their idle mixtures fairly rich to get the bike to start.
    But the ignition system voltage was so low they still had to gap their
    spark plugs down to 0.025".
    With a gap that tight, it was a hit or miss proposition as to whether
    any burnable mixture would be near the gap when the spark jumped.
    The solution in those days was to fit K-Mart ignition coils to
    Japanese motorcycles.
    They put out 35,000 volts and would make an inch long spark in free
    air.
    The K-Mart coils cost only $6.66 and the extra voltage made it
    possible to open the spark plug gap to 0.035", making the engine
    easier to start.
    The Chevy HEI system you mentioned will make it possible for you to
    open your spark plug gap so the weak mixture will find the fire...
    Gus, Jun 19, 2011
  3. frogliver
    Gus Guest
    You always wanted me to be your daddy, didn't you?
    C'mon, 'fess up.
    Everybody knows it...
    Gus, Jun 19, 2011
  4. This is total, utter, complete, hallmarked, attested, certified and
    triple-plated nonsense.
    Not only did I, and everyone I knew back then, *never* have a problem
    starting any of the many machines we owned in the 1970s[1], but I even
    have a 1970s machine today, running a completely stock 1970s ignition
    system, and it starts perfectly. Every time.
    You know nothing.
    [1] Well, Steve with his Triumph TR6R had some moments...
    The Older Gentleman, Jun 19, 2011
  5. frogliver
    Gus Guest
    You never even knew there was a *problem* or what the engineering
    solutions were, fool.
    Gus, Jun 19, 2011
  6. frogliver
    frogliver Guest
    This bike starts O.K. It just takes six miles of riding to get to where you
    don't need to choke it. It is a pain since the first intersection I hit is
    on a highway 1/2 mile up the road and it wants to die at the stop sign
    unless I add more choke.
    What about this K-mart coil? Do you think I can still get one?
    I also have a 1971 CB350 that runs great -- only needs choking to start up
    when cold then I shut the choke right off and go -- the same with a 1971
    CB450 I once had.
    frogliver, Jun 19, 2011
  7. There was no problem.
    Sure, some bikes can be buggers to start - I remember by SR500 single
    definitely needed the 'knack' (but once acquired, it was a first, or at
    worst second, kick starter).
    You're saying that 1970s Jap bikes were hard to start, which is your
    usual bullshit.
    Keep dancing.
  8. frogliver
    Gus Guest
    I haven't seen ignition tune up parts and coils at K-Mart for many
    years, but I'm sure you can use almost *any* automotive coil that was
    designed with ignition contact point systems in mind.
    In order to rev small displacement engines to high RPM which requires
    the magnetic field in a coil to break down rapidly the Japanese
    engineers accepted a voltage compromise.
    The smaller, lower inductance coils only put out about 9,000 to 12,000
    volts maximum.
    There is a property of coils which is called "inductance."
    As each turn of copper wire in a coil is energized, it causes a
    counter-electromotive force which opposes the energization of the next
    turn.
    So, having smaller coils with less iron inside made it possible for
    the coil to charge and discharge more rapidly.
    Unfortunately, that discharge time still wasn't fast enough to avoid
    the high voltage from bleeding off across the carbon on the nose of
    the spark plug.
    Electronic ignition systems are able to make and break the primary
    circuit more rapidly than a set of ignition points can.
    Also, the high current through a set of contact points rapidly burns
    and erodes
    ignition points.
    Motorcycle enthusiasts who installed K-Mart coils would often install
    a 6-volt coil with a ballast resistor which used full 12 volts during
    start up, then the resistor would heat up and drop the voltage back to
    6 volts.
    I bought a solid state electronic "ignition amplifier" to reduce
    current through the points by using a switching transistor.
    Gus, Jun 19, 2011
  9. frogliver
    Gus Guest
    How would *you* know?
    You weren't riding motorcycles, you were giving blowjobs to the senior
    boys at boarding school in the 1970's.
    Gus, Jun 19, 2011
  10. Krusty gets it wrong *again*. You need to work on your stalking. Got my
    first bike in 1976, the year I went to university.
    And, sweetie-pie, I've owned more bikes than you could possibly dream
    of, 1970s and later :))
    Keep dancing.
  11. Krusty gets it right at last. Monkeys, Hamlet, typewriters, etc.
  12. frogliver
    Keith Guest
    no I've always wanted an excuse to end you existence...
    Oh btw in case you didn't know. Your advice is dead wrong...it's the
    idle jets. You stupid pedophile.
    Keith, Jun 19, 2011
  13. frogliver
    Gus Guest
    No shit.
    Gus, Jun 20, 2011
  14. frogliver
    Keith Guest
    Nope I shit you not you perscription drug abusing child molester. Your
    advice was as always dead fucking wrong.
    I do hope some nice californians hang you with your entrails...while
    you are still living.
    Keith, Jun 20, 2011
  15. frogliver
    Gus Guest
    I know. A turd was the first friend you ever had, and you cried when
    Mommy took the potty away...
    Gus, Jun 20, 2011
  16. frogliver
    Keith Guest
    You know child rapists like you are the most hated people in the world
    and that's before anyone finds out the kind of scum you are. Then,
    they start drawing straws to see who gets to kill you...
    I hear you've got time, it's a large pool and many people haven't
    drawn a straw yet.
    Keith, Jun 21, 2011
  17. frogliver
    Gus Guest
    You should get a job in a movie theater, you're always projecting.
    Gus, Jun 21, 2011
  18. frogliver
    Keith Guest
    lol and now you qoute me, you insane alzheimers addled fraud.
    Keith, Jun 22, 2011
