76 honda fouling problem....help
Discussion in 'Motorbike Technical Discussion' started by BGP, Sep 11, 2004.
  1. BGP
    BGP Guest
    I have a 76 Honda 360 that is carbon fouling one plug badly and the other to
    a lesser extent. It starts to cut up at around 4000 rpm's. I tried
    adjusting the fuel air mixture both lean and rich and It runs like hell 1/2
    turn either way (adjusting both carbs) What does a dry black carbon foul
    mean. could it be the gap or coil? how do I check it? hung Float? rich?
    lean? this is a sudden problem. but I did just get it and babied it for a
    while, was told when this started to "get on it and burn the carbon out,"
    did not work.
    any ideas? I'm out.
    thanks
    bg
    BGP, Sep 11, 2004
