'76 CB200 speedo drive.
Discussion in 'UK Motorcycles' started by ian field, May 12, 2009.
  1. ian field
    ian field Guest
    This TLS front brake model CB200 (front hub looks same as CB175) has
    suffered intermittent speedo - I've checked by replacement the speedo head
    and cable and checked the speedo drive gear and driven gear by gripping the
    drive tang and trying to turn the drive gear - the teeth don't slip.
    That only leaves the tangs on the drive gear that engage with the milled
    slot in the face of the wheel bearing housing, should the drive gear have a
    spring washer behind it to push these tangs into the milled slot?
    TIA.
  2. No, but there is a large plain washer that goes between the drive and
    the inner hub.
    The Older Gentleman, May 12, 2009
  3. ian field
    ian field Guest
    Do you mean between the drive gear and brake plate?
  4. No. IIRC, it's on the inner side. Haven't you got a manual with a
    schematic?
    Try http://www.cmsnl.com
  5. ian field
    ian field Guest
    Haynes #067 - P86. The speedo drive gear is #2 in the exploded view, the oil
    seal for the speedo gear recess is #19, there are no washers of any
    description associated with either part - a large washer between the gear
    and central hub would be impossible to center/retain in place while fitting
    the wheel and would separate the drive tabs from the slot milled in the hub
    bearing face.
  6. It's more of a shim than a washer, and I know it's in there somewhere
    because I've dismantled loads of them.
