'74 FX OEM Wiring
Discussion in 'Motorbike Technical Discussion' started by ., Oct 10, 2004.
  1. .
    . Guest
    1974 kick start Superglide, sans turn signals, instrument lamps
    and accompanying wiring:
    Under the headlight mount/cover, that bolts to the top triple tree,
    is a five junction terminal strip. At an end terminal point is 4 wires,
    3 orange (two 18 gauge and one 16 gauge) and 1 black. The larger
    orange wire has a nearly 2 amp current draw with the ignition key
    OFF, but only half an amp pull with it on (probable bad switch?).
    Would someone with access to a wiring diagram confirm where
    that orange wire goes (unlike the other two orange wires that enter
    the left and right handcase harnesses respectively, this one enters
    the main engine/chassis harness).
    Thanx in advance.
    ., Oct 10, 2004
    . Guest
    Sorry to bother everyone with this, hadn't expected to find it on the
    net,
    but there it is:
    http://mysite.wanadoo-members.co.uk/hhog/diagrams/19_1973_74_FX_.gif
    ., Oct 10, 2004
